October 8, 2007, 02:02 |
acoustic and noise simulation
Hi; Can star-cd simulate (calculate) the intensity of a high speed jet noise? If no, do you know a software that can perform such a simulation?
October 16, 2007, 04:16 |
Re: acoustic and noise simulation
There are two methods:
The Lilley source technique which gives quick and qualitative information. The other is to run transient with DES turbulence and pick up fluctuating pressures at some locations. Then pass this through a FFT program to get local dB, or send to a noise prop. program like Actran or SYSNOISE to get propagation information away from the jet. To make the latter technique easier, it and other tools are included in the Expert System add-in called es-aacoustics, purchased separately. |
August 10, 2009, 05:01 |
noise simulation
dss
Rep Power: 16 |
Does cfx simulate the flow noise?
Every one, do you know whether the cfx post can analysis the resluts? Thinks! |
Display Modes | |
Acoustic simulation | Hugh | FLUENT | 0 | October 1, 2006 21:54 |
CFD Acoustic | Michail | Main CFD Forum | 0 | August 20, 2005 19:06 |
acoustic | Z | Main CFD Forum | 0 | February 25, 2005 10:33 |
relating slosh simulation to noise pollution | Johannes Hagemann | Main CFD Forum | 0 | July 20, 1999 07:20 |
ACOUSTIC / WIND NOISE / AEROACOUSTIC | Jallet | Main CFD Forum | 1 | February 17, 1999 19:48 |
