What version of Fortran match Star-cd V 3.24
Old   April 17, 2006, 22:51
Default What version of Fortran match Star-cd V 3.24
Tipakorn
I use Star CD v 3.24 but I don't what version of Fortran match this Star CD. Should I install Fortran before or after installing Star CD?
Thank you
Old   April 18, 2006, 07:41
Default Re: What version of Fortran match Star-cd V 3.24
A Student
Use the search function of this web-site.
Good luck.
Old   April 18, 2006, 07:56
usker
You can use Absoft Fortran Compiler V8.0. Before or after it does not matter, but you will need to set up environment variables to link your system with this Fortran Compiler. If your system is Windows then just go to My Computer-> Properties-> Advanced->Environment Variables, and type the link to the Fortran Compiler.
Old   April 19, 2006, 23:35
tipakorn
Thank you I have more question. Can I use Fortran Compiler v9.0? And what do I type when linked my system with Fortran Compiler?
Old   April 19, 2006, 23:47
usker
I beleive you can use Fortran compiler V9.0. After you install fortran compiler, for example if it is Absoft 80, then you type:
ABSOFT C:\Absoft80
INCLUDE C:\Absoft80\FINCLUDE;
LIB C:\Absoft80\LIB;
Path C:\Absoft80\BIN;
Old   April 20, 2006, 01:10
Particle
If I use parallel grid computer to run Star-CD, may I need to link the Fortran compiler to every grid computer's CPU? For example, grid2(CPU) links the same Fortran compiler after the grid1(CPU) linked the Fortran compiler, is it?
Old   April 20, 2006, 13:59
TG
NO - you don't link computers to programs with a compiler. You link a program once and that executable runs on all the nodes in the cluster, assuming they are all the same architecture and OS.
Old   June 2, 2006, 02:51
bioman66
Dear Usker Following this question, I set the environment variables as you said. But when I built a mixing vessel geometry in mixpert of pro-star and press "process", an error message "fortran runtime error ......" appear, I can not figure out what's wrong. Could you teach me how to solve this problem? I use star-cd 3.22 and absoft pro fortan 9.0.
Old   August 10, 2011, 02:08
abstrused00388@gmail.com
abstrused00388 is on a distinguished road
Originally Posted by usker
;171217
ABSOFT C:\Absoft80
Where to type theses ?? in star cd Command prompt or in environment variables in Windows ??
With Regards ,
SanZ
[I Will Have Plenty Of Doubts. So,
Send me Your Solutions Faster ! ]
abstrused00388 is offline   Reply With Quote
which version of fortran for starcd 4.06? whitemelon Siemens 1 June 22, 2008 12:22
fortran version for star v.4 matej Siemens 2 August 15, 2007 08:06
FLUENT Version Mis-Match Discrepancy asd Main CFD Forum 0 April 19, 2007 04:58
the GUI version of fortran 95 compliler ztdep Main CFD Forum 2 June 29, 2005 00:37
Visual fortran for 3.5 version? user Phoenics 2 November 9, 2004 20:59
