June 15, 2004, 20:01 |
Train Simulation Entering A tunnel.
Hi Everybody!
One more time I would like some advice about a problem occured in Star-CD. I have tried to simulate a train entering a tunnel using the Star-CD. Currently there are some problems especially with the creation of the mesh and the simulation of that. I have a couple question if anyone of you might know (Hopefully yes!). 1) Is there any other (easier) way to simulate the train entering a tunnel without having to create "blocks" that will slide relative to each other? Because, it would be easy to do it in a 2D mesh but extremely complicated to perform that in a 3D enviroment.. ( different subroutines, different and more precise meshes) 2) Is it possible to create multiple "static models" ( many different meshes with the train in different positions, just before entering, when it enters and after it has enter) and then compile all the data together to produce an overall result of the simulations? (when the train and the tunnel will be "static" the only parameter that is going to change will be the air flow coming from inside the tunnel in close distance from the front of the train) Any suggestions, comments or just simple ideas are more than welcome! Currently I have looked similar cases, but none of them was created (only) in Star-CD. It would be better if I create a 3D simulation rather than a 2D. This would be a MSc disertation and I must use star-cd. If more informations are required (such as blockage ratios or dimensions or speed of the train) are needed please contact me. Thanks in advance. Regards Christos |
June 16, 2004, 03:13 |
Re: Train Simulation Entering A tunnel.
In reference to your questions
1. No, there isn't another possibility 2. No, you can't use multiple static models. This approach doesn't consider transient effects. b.g. F.K. |
June 16, 2004, 11:12 |
At first try to make 2D model. Start with the simplest case to understand how the sliding mesh works. First step - tutorial 11 in STAR-CD. The other cases can help you with some ideas how to set the model, even they are performed using other codes. In this case you will need to make 3D model, because you will have effects on all sides of the train. The final model should be 3D train entering tunel, transient case.
Good luck! |
June 16, 2004, 20:26 |
I have already started building the 2D model in low detail, lets see how this is going to turn up and then i will try the more complicated 3D one..
Thanks for all your help and suggestions! I will post more questions if I have, thanks again! Regards Christos |
June 17, 2004, 05:04 |
There is a way to avoid using cell layer removal and addition. Taking the example of tutorial 11, if you can have very fine mesh at the rear side of train and relative coarse mesh at the front side of train, then when the train moves, you just adjust the mesh by mesh movement.
May 15, 2010, 16:59 |
trains
Antonis Kantas
υπαρχει καποιος κυριος να μου πει αν υπαρχει online συστημα για εξομοιωτη τραινων? απαντηστε μου στο mail antoniskantas@otenet.gr
January 30, 2012, 01:24 |
Rep Power: 14 |
hi,
i am also trying to apply 2D sliding mesh technique to train moving in tunnel , but not able to do it . can any body help me plz |
February 6, 2012, 07:02 |
sliding mesh
Rep Power: 14 |
hello , can any body help me in sliding mesh used in train traveling in tunnel. my email is sheikhnasir39@gmail.com
thanks with regards |
Display Modes | |
Train Simulation Entering A tunnel Part No 2... | Christos Sfyris | Siemens | 2 | February 15, 2012 09:59 |
Help need in modelling train-tunnel interaction | xyx | FLUENT | 1 | February 14, 2012 08:29 |
Effects of a moving train to people in a tunnel | J. Kim | FLUENT | 5 | February 14, 2012 08:26 |
wind tunnel and simulation results different | richard | FLUENT | 2 | February 14, 2012 08:06 |
wind tunnel simulation | Andres Paez | FLUENT | 1 | August 15, 2008 00:17 |
