August 12, 2014, 06:44 |
centrifugal seal
sanandtv
Rep Power: 15 |
hi i am working on centrifugal seals where the interface between air and a rotating liquid core is to be tracked. I am planning to do in ANSYS CFX. Anybody has done anything on this area? thanks in advance....
August 12, 2014, 09:19 |
Marcin
Rep Power: 12 |
You must describe your problem more precize. And drawing will be important too.
Best regards |
August 12, 2014, 09:42 |
Hemen Shah
Rep Power: 12 |
Hi-Tech has done projects in this vertical and will be happy to assist you in your project. Please visit : www.hitechcfd.com for our services. Please email me more details of the requirement at hemen.shah@hitechos.com. Looking forward to hear from you. Regards Hemen. |
August 14, 2014, 11:37 |
sanandtv
Rep Power: 15 |
hi...thanks for the reply..can u give ur mail id..? i will send a schematic of the problem to you.I have a liquid at some pressure > atmospheric to be sealed. I am planning to used a centrifugal seal for this purpose, wherein a disc mounted on a shaft is rotated at some angular velocity. The liquid to be sealed is supplied axially to the disc on one end. Due to centrifugal action the fluid is held against gravity on the other end, there by preventing it from going out (sealing) as long as the disc rotates. I want to predict the interface between the liquid and air with CFD. I am fairly new to CFD, tired many methods, but not successful.
August 14, 2014, 12:12 |
Hemen Shah
Rep Power: 12 |
My email id is hemen.shah@hitechos.com. You can forward the drawings on this id. Regards Hemen. |
Display Modes | |
centrifugal pump | Chalghoum | CFX | 18 | April 16, 2014 07:37 |
Autoblade centrifugal pump template | mahdi balali | Fidelity CFD | 3 | February 18, 2014 09:56 |
Centrifugal Pump Cavitation problem or not. | ismael.s | CFX | 13 | February 27, 2012 09:00 |
How to model flow of centrifugal fan? | Peter | Main CFD Forum | 0 | April 2, 2008 07:07 |
centrifugal pump and centrifugal fan | Mangesh | Main CFD Forum | 3 | January 3, 2006 12:21 |
