Vortex Generator mesh
2 Attachment(s)
Hi guys, I am trying to mesh this geometry i made in NX 9.0 of a vortex generator in ICEM CFD . Issue arising is low quality mesh . I actually dont know how to mesh this geometry properly or if the geometry is correct itself. Any help regarding this would be highly appreciated
TIA. |
You can contact me on abhishek.bhagwat1@gmail.com. I am in IIT Bombay
Hi there,
if you know the equation for the "domain outline" then the following approach should work: i) Mathematica (for example) for generation of edge vertices ii) OpenFOAM'S mesher blockMesh to generate a clean and well-conditioned hex-mesh based on the vertices provided from i). Good luck |
1 Attachment(s)
Hi, So i managed to get some work done and here are the details , i did it in workbench > fluid flow (fluent)
Model is : A simple solid triangle kept at 15° to inlet . I need to investigate flow over it. 1.Modelled CAD geometry in Designmodeler , created enclosure and subtracted the specimen . 2.meshed with medium density ( no parameters changed ) 3. inlet velocity at 22.22m/s , k-e equation . standard init. and rest all parameters were default Then i got this scaled residual graph, can someone say what does this graph denote ? |
Give more importance to the y+ paramater and the dynamic mesh
Dear RohIIT,
You are making mesh on the vortex generator itself. :mad: You should make enclosure around the vortex generator and then try to mesh fluid domain. Regards, Er. Max |
Yes i later understood that and did simulation runs . Fluid domain is roughly 15X dimensions of the model of VG. Still i dont know if the results obtained are correct or not, also i dont get convergence due to absence of finer mesh. |
Guys, In fluent , how can i find boundary layer thickness , its a vortex generator placed over a flat plate .
Also i have obtained convergence , so how can i find circulation i.e vortex strength around the VG ? |
