January 2, 2019, 13:56 |
What is an eddy length scale?
Mostafa
Rep Power: 9 |
Good day everyone
I know this question might sound trivial, but I have been struggling and searching in books on turbulence to find a clear explanation to what an eddy size is? What is the characteristic length? and what is the length scale? I've understood that there is a wide range of length scales for eddies, ranging integral turbulence to Kolmogrov. However, I can't quite grasp or feel what they actually refer to. If someone could explain these terms or refer a book that illustrates their physical meaning, I'd be so grateful. Thank you |
January 3, 2019, 11:11 |
Rep Power: 14 |
According to my understanding (you should double check): There are different eddies with different sizes in turbulent flow. The eddy which contains most of the energy has a length called the integral length scale. Kinetic energy is transferred between the eddies from the largest scale to the smallest eddy which has a length equal to Kolmogorov length scale and energy is dissipated into heat at this small scale. you can see these presentation http://www.bakker.org/dartmouth06/engs150/09-kolm.pdf |
January 3, 2019, 18:29 |
Mostafa
Rep Power: 9 |
Thank you for your answer. This presentation has helped a lot.
Turbulence length scale and integral length scale | rizhang | CFX | 2 | April 22, 2016 07:22 |
Modelled Length Scale in SAS-SST Simulation | jego | Main CFD Forum | 0 | January 16, 2016 06:45 |
Smallest length scale in Large eddy simulation | maphd | Main CFD Forum | 12 | August 8, 2015 13:04 |
calculation of eddy length scale | nathalie | FLUENT | 0 | February 2, 2009 12:05 |
How to determine eddy length scale? | Zaidun | CFX | 1 | March 27, 2006 20:12 |
