Home > Forums > General Forums > CFD Freelancers
air dancer maximum height problem, step by step
Old   January 5, 2019, 08:30
Default air dancer maximum height problem, step by step
Aleksey_at_cfd is on a distinguished road
Please look at this thread : air dancer maximum height problem
I am willing to pay for help. I want to do this by small steps.
The first step is very simple, analytical, like this
I will start from a simple model in laminar case: Hagen-Poisueille solution in a pipe. That has a pressure decreasing along the axis. The weight sustained at a certain height must be balanced by the total wall stress acting at a that height.
Actually, when the flow starts transition, you have vortical structures in the pipe that will cause the fluctuation of the pressure.
You have an analytical solution for the velocity, you can compute the stresses at the wall and integrate them along the surface up to the height until you get a force that sustains the weight.
The next steps should be using some CFD IDE to model the same for turbulent flow, introduce that "vortical structures", take into account the features of the walls, etc.
Aleksey_at_cfd is offline   Reply With Quote
courant number in vof reza_gharib1369 FLUENT 49 February 26, 2020 16:55
p_rgh initial residual no change with different settings manuc OpenFOAM Running, Solving & CFD 3 June 26, 2018 15:53
successful time step for 2D problem failing for 3D case of same problem. mandman Main CFD Forum 6 March 10, 2015 19:01
1-way time step problem in doing FSI between Fluent and Transient Structural sihaqqi ANSYS 0 November 21, 2013 02:45
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
