July 27, 2019, 23:40 |
VOF model versus species transport model
Nikhil Bhat
Rep Power: 14 |
Dear All
I just need some urgent guidance at the initial stage of modeling. Willing to pay for the hep. However the project is very urgent so require immediate help. See below for description I am having a domain (just a simple box domain). Inside the domain there are some chemical reactions taking place which results in release of heat, water vapor, carbon-di-oxide and ammonia. I want to disperse the CO2, NH and the water vapor out of the domain Now i am blowing dry air through one end of the box which will help me carry away the contaminants (CO2, NH and water vapor). The other end of the box is exposed to atmosphere. So one side is Velocity Inlet(for air), other side is pressure outlet(as exposed to atmosphere). I want to study the effectiveness of the air at a certain velocity to disperse the contaminants I am not sure which model should i go for VOF or species transport model? Kindly advise Thanks in advance |
July 28, 2019, 11:42 |
PEC
Rep Power: 6 |
Hello Sir
This Is Paramesh I can help you with this. You can contact me at 8074810789 or write to me at dvparameshpec@gmail.com I'm an expert in Design, Drafting, and Simulation with industrial experience from the past 13 years. I'm involved in industrial, research and academic projects in various domains. My Expertise in the areas of CFD, Multiphysics, FEA problems. My specialization is in analysis and simulation of noise, vibrations, acoustics, and combustion. I can help you in the following areas ✓ Static stress analysis: Linear, Non-linear, Buckling/Postbuckling ✓ Dynamic analysis (eigenvalues, vibrations) ✓ Composite materials (carbon fiber, glass fiber, wood, etc.) ✓ Topology optimization ✓ Weight optimization ✓ Joints analysis (bolts, welding) ✓ Crash simulations ✓ Conjugate Heat Transfer & Multiphase Analysis ✓ Fluid Flow Analysis ✓ Combustion Analysis ✓ Noise, Vibration, Harshness & Acoustics ✓ Heating Ventilation & Air Conditioning I have experience in working with simulation software like ✓ ANSYS ✓ Star CCM+ ✓ OpenFOAM ✓ Comsol Multiphysics ✓ MSC Nastran ✓ ABAQUS ✓ LS Dyna ✓ Hypermesh looking forward to work with you regards |
December 22, 2019, 06:34 |
habibjalili
Rep Power: 7 |
Let's talk about the details of the project. 1-chemical reactions are going to happen inside the box? do you want to simulate this or simulate after the reactions? 2- how do you want to remove the gases? we can use the membrane. |
How to find indexes of the species in species transport model | Nishant_Sharma | Fluent UDF and Scheme Programming | 13 | September 27, 2023 09:53 |
Species transport model problem | argeus | FLUENT | 8 | September 20, 2019 07:23 |
VOF with Species Transport results in continuity equation blowing up | pramodnarayan | Fluent Multiphase | 1 | October 14, 2015 17:04 |
the difference of species transport and non-premixed combustion model | Messi | FLUENT | 0 | June 30, 2014 04:30 |
Species transport model | Karthick | FLUENT | 0 | May 11, 2004 03:47 |
