Home > Forums > General Forums > CFD Freelancers
Help ICEM 3D cylinder with no holes baffles at an angle
Old   July 16, 2020, 04:01
Default Help ICEM 3D cylinder with no holes baffles at an angle
Bola
Famous is on a distinguished road
Hello everyone
I have recently been struggling to mesh baffles which are inclined, one at 15 degrees and the other at 30 degrees. The reason i am struggling with this is because I am trying to make sure I have fine meshes around the baffles in order to fully capture boundary layer effects for the cylinder and the baffles. I was hoping someone could give me a step by step guide on how to go about this as this has been proving very difficult for me . I have attached the models below (geom) which you can just transfer to icem.
I was using blocking and o-grid to do this as i did this for the baffles without angles and they worked fine.
Famous is offline   Reply With Quote
Old   July 24, 2020, 14:18
Nikhil
nikhilkulkarni4013 is on a distinguished road
Originally Posted by Famous View Post
Hello everyone
I am having 2 years of experience in ICEM CFD and I can support you with this task. Please DM me the details,
Thank you,
Nikhil
nikhilkulkarni4013 is offline   Reply With Quote
Old   August 5, 2020, 00:45
Arslan Saleem
asaleem89 is on a distinguished road
I can guide you if you still need help!
asaleem89 is offline   Reply With Quote
Old   August 14, 2020, 16:02
Carter83 is on a distinguished road
Just info for the others - I did the mesh, we agreed on the conditions. However, Famous did not honor his part of the deal. So be warned before trusting him...
Carter83 is offline   Reply With Quote
[ANSYS Meshing] Meshing 3d circular cylinder in ICEM darazsbence ANSYS Meshing & Geometry 0 March 11, 2014 16:35
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
ICEM: Holes in Geometry Daniel CFX 4 February 22, 2009 09:40
angle of attack with icem hexa icem beginner Main CFD Forum 0 December 5, 2008 16:54
ICEM block mesh with a ball in a cylinder tube Li CFX 6 August 11, 2008 05:44
