Help needed for structured hexahedral mesh generation in Ansys to be used in Fluent |
March 3, 2022, 19:20 |
Taosif Alam
Rep Power: 5 |
Hi!
I would like need a help to create a structured hexahedral mesh for a simple 3D rectangle geometry. The dimension of the rectangular block is 1000 x 300 x 350 um^3. The mesh needs to be densed with in a 750x100x150 um^3 region from the top surface within the rectangle block. The element size in the densed region can be 3, 4 or 5 um. Also, beyond the densed region, the mesh can increased element size but needs to be structured. If you are interested, we can talk further in email. You can reach out to me at taosifme014@gmail.com. Thanks |
March 6, 2022, 04:32 |
Use HexGrid for mesh generation ?
Mads Mammen
HexGrid has a demo of a box - can be extended for your use.
HexGrid is mentioned in 'News' some days ago. The mesh file is .cgns can be converted to .msh using ANSYS cfx5convert utility. |
May 15, 2022, 06:57 |
Alain Islas
Rep Power: 6 |
If help still needed, I can create this mesh using ICEM CFD. File will be .msh
ansys, meshing 3d, structured hex mesh |
[Other] [Request] OpenFOAM mesh to 2D Ansys fluent mesh | anon_q | OpenFOAM Community Contributions | 6 | July 3, 2023 05:24 |
[ANSYS Meshing] How do I open a mesh made in Ansys Fluent 2020 R2 on Ansys Fluent 2019 R3? | Ryan T | ANSYS Meshing & Geometry | 3 | November 3, 2021 15:44 |
Transfer of mesh from Meshing to Fluent destroys the mesh | balrog_f | FLUENT | 9 | July 28, 2018 10:02 |
Ansys mesh for FLUENT software giving unrealistic results, while GAMBIT mesh is fine | kbhamidipa3 | FLUENT | 0 | November 30, 2012 15:52 |
Mesh generation software is needed | H.Dou | Main CFD Forum | 12 | May 4, 2011 15:20 |
