Home > Forums > General Forums > CFD Freelancers
error in meshing, file not being read
Old   August 9, 2022, 08:46
Default error in meshing, file not being read
West Midlands
R786 is on a distinguished road
Hi
I have this issue in meshing using OPENFOAM, how can i solve this, i have made my stl files using blender, and few days back it meshed OK, now when i changed and partitioned my stl files into separate parts, it does not mesh and cannot read my file named body. Also i changed it to ASCII and removed the binary code. What is the issue i cannot spot please can i have some help,
Procs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Note: Feature line extraction only valid on closed manifold surfaces
Reading surfaceFeatureExtractDict
Surfaces : body.stl
Output : body
Load options : offset
Write options: writeObj=off writeVTK=off
--> FOAM FATAL ERROR: (openfoam-2106 patch=211215)
Cannot read file "/home/rabia/RabiaOpenFOAM/RabiaNew/UpwardFanRabia/constant/triSurface/body.stl" or file "/home/rabia/RabiaOpenFOAM/RabiaNew/UpwardFanRabia/constant/triSurface/body.stl.gz"
From static int Foam::fileFormats::STLCore::detectBinaryHeader(con st Foam::fileName&)
in file stl/STLCore.C at line 100.
R786 is offline   Reply With Quote
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 04:50
Using PengRobinsonGas EoS with sprayFoam Jabo OpenFOAM Running, Solving & CFD 35 April 29, 2022 16:35
[OpenFOAM.com] swak4foam compiling issues on a cluster saj216 OpenFOAM Installation 4 February 27, 2020 16:57
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
