Home > Forums > General Forums > CFD Freelancers
Heat and airflow simulation
Old   February 27, 2025, 04:19
Default Heat and airflow simulation
Stefan Nettesheim
Stefanetti is on a distinguished road
I would like to get an offer for a flow simulation and visualization of the following: Assume a field of 100m x 100m with heat sources of each 1kW placed every 10m in a 10x10 equidistant matrix. The ground should have a temperature of °C and the ambient air also °C. Visualize the flow in xy plane at z= 10cm, 1m, 2m, 10m height. Also visualize the flow in the xz plane at one of the boundaries and in the middle of the xy-plane.
Thank you
Stefanetti is offline   Reply With Quote
Old   February 27, 2025, 23:15
Ryan
RavingRaven is on a distinguished road
Good day, Stefanetti
I hope you're doing well. That sounds like a practical problem to simulate. I have sent you a private message with further details where we can discuss this further, if possible. Have a good day.
RavingRaven is offline   Reply With Quote
airflow, heat
Nose air flow (Respiratory cycle) simulation with heat and Humidity exchange AhmSam FLUENT 0 June 2, 2023 20:00
Including heat from Lighting fixture for internal building airflow analysis prom Main CFD Forum 0 June 16, 2021 04:43
Heat Transfer Disc Brake tacitosantos CFX 6 July 26, 2016 01:34
Heat Transfer from airflow to concrete Mary2788 FLUENT 1 June 22, 2011 10:43
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 20:28
