Home > Forums > CFD Online Community > CFD-Wiki
Is it possible to change a CFD-Wiki username?
Old   January 12, 2006, 00:22
Default Is it possible to change a CFD-Wiki username?
Nina Shokina
Hello Jonas,
I guess this question should be addressed to you.. Is it possible to change a CFD-Wiki username?
Thank you!
Old   January 12, 2006, 02:37
Default Re: Is it possible to change a CFD-Wiki username?
zxaar
i think you can register with new name and ask the admin to delete the one you created before.
Old   January 12, 2006, 06:15
Jonas Larsson
It isn't possible to change your name, if there is a strong wish to add this feature it can be done though. It requires a special add-on to be installed to the Wiki software.
Deleting a user is not possible or advisable though - since the Wiki has full revision control and stores all history deleting a user would mess up this.
Old   January 12, 2006, 08:54
Nina Shokina
Thank you for an answer. It would be good to have this feature in the future. Is it a problem to install it?
Old   January 12, 2006, 09:03
Jonas Larsson
I have installed the extension to rename user. Just let me know which username you would like to change from and to.
Old   January 13, 2006, 01:41
zxaar
Dear Jonas, I am still not able to connect to wiki from office, from where i can actually work. Is there any solution to this problem. This problem seems to appear after one day when i saw somebody put lot of spam text in wiki, so i quickly opened few pages and deleted that text and saved the page again. After that i guess i could never be able to access wiki.
Old   January 13, 2006, 06:50
Jonas Larsson
Yes, it is a spam filter which I have installed which prevents non-standard-compliant web-browsers from editing the Wiki (typically most spam-bots fail to be 100% standard compliant). It is very effective against these spam-bot vandals, who were creating a mess in the Wiki.
The error message recorded in the spam-filter logs for your IP number is "Prohibited header 'Proxy-Connection' present". Apparantly this header should not normally be present when accessing the Wiki from a normal browser. I don't know why it is for you. It is most likely an error with how your company's web-proxy is set up. Anyway, I will disable this particular check for now. So it should work for you now. Please let me know otherwise.
I'm actually having a similar problem when I try to access the Wiki from my job (Volvo Aero). I think that the reason is some miss-match betweenn IE and Volvo's web-proxy. If I use Mozilla it works! So you might try to use Mozilla or Firefox instead (assuming you are using IE now).
I apologize for the problems zxaar!
Old   January 13, 2006, 07:43
Nina Shokina
Thank you very much, Jonas! I've sent you an e-mail with details.
Wiki gschaider OpenFOAM 178 December 31, 2014 07:34
Wiki Dan Main CFD Forum 1 February 4, 2007 18:14
Getting CFD-Wiki Going Again Jonas Larsson CFD-Wiki 20 May 15, 2006 01:12
CFD-Wiki - We Need Your Help! Jonas Larsson Main CFD Forum 5 May 12, 2006 08:25
CFD Wiki - We Need More Help Jonas Larsson Main CFD Forum 13 September 13, 2005 17:36
