Setting Opening Boundary to Move Normal to Itself
Old   April 18, 2012, 14:36
Post Setting Opening Boundary to Move Normal to Itself
Nick Cleveland
NCle is on a distinguished road
Is it possible in CFX to prescribe mesh motion of an opening-type boundary, normal to that boundary?
I am modeling a stamping process with 2-way FSI in ANSYS. The stamp is the elastic solid that presses down into a high viscosity fluid, which has a free surface in contact with air. I must let the air out as the solid stamp presses down, so the opening boundary allows for that. However, extreme stretch that causes error occurs at the edge of the FSI where the ANSYS Mechanical domain meets the CFX domain (I have circled the spot in the attached pic). This stretching is from the stamp moving down but the opening boundary adjacent to it being fixed in place.
The error occurs in Mechanical, and the ANSYSout message is:
"*** ERROR *** CP = 200.040 TIME= 12:20:50
One or more elements have become highly distorted. Excessive
distortion of elements is usually a symptom indicating the need for
corrective action elsewhere. Try ramping the load up instead of step
applying the load (KBC,1). You may need to improve your mesh to
obtain elements with better aspect ratios. Also consider the behavior
of materials, contact pairs, and/or constraint equations. If this
message appears in the first iteration of first substep, be sure to
run shape checking of elements."
and occurs right as the CFX monitors start up in the solver.
NCle is offline   Reply With Quote
Old   April 18, 2012, 14:39
Default picture of model
Nick Cleveland
picture of model
Old   April 19, 2012, 09:11
You do not want the opening to move. It will stuff up the boundary condition.
Have you considered using a GGI interface to make this motion use a simpler mesh motion?
Old   April 19, 2012, 10:17
Default Ggi
Nick Cleveland
No, haven't considered GGI for the FSI. I am now reading about GGI and trying to figure out how to implement it. Thank you for the advice and your time.
The help directory in CFX says GGI "performs an intersection procedure to connect the two sides of the interface together", which sounds like what I need, because there seems to be poor communication between CFX and ANSYS Mechanical.
When I increase the viscosity closer to that which I need to model, this error occurs. It seems like the model handles "water" just fine but can't model "honey" without ANSYS returning the "excessive element deformation" message. I suppose with high viscosity the liquid puts too much shear force on the vertical FSI for ANSYS and CFX to exchange info there. Or, high viscosity fluids cant be solved in distorted elements as easily as low viscosity ones. Perhaps GGI will allow me to model the thick liquid.
The CFX outfile says that CFX "failed to get total mesh displacement" from ANSYS when I raise viscosity.
Can I simultaneously set the FSI interface boundary to be GGI, and also, where should I set it to GGI? In CFX, ANSYS Mechanical, or both?
Thanks again.
Old   April 19, 2012, 10:22
Default I found tutorial
Nick Cleveland
ghorrocks,
I found a tutorial with GGI in CFX, so I will do that to find out how to use it.
Thank you.
Old   April 19, 2012, 10:30
Default Chp 17
Nick Cleveland
Its Chp 17: M.ultiphase F.low i.n a. M.ixing V.essel
Incase anyone needs it.
Old   April 19, 2012, 11:13
Nick Cleveland
Do you know if it is possible to create a GGI-type interface between the solid and fluid domains in a 2-way FSI model?
I'm having trouble, because the solid domain is only in ANSYS Mech, so I can't prescribe the domain interface to be "fluid-solid", only "fluid-fluid" , as that is all that is in my CFX domain. I need the solid to be in ANSYS Mech so I can solve for strain and apply displacement.
I assume the only way to select GGI is to create a new domain interface in CFX-pre. But when I do this, one of the "mesh motion options" is not "ANSYS Multifield" as it needs to be to set up the two-way info sharing between ANSYS Mech and CFX. An option is "ANSYS Multifield" only when I just make a regular wall boundary at the CFX/Mech interface, but this regular wall boundary doesn't let me use GGI.
Old   April 19, 2012, 12:10
Default mesh lined up
Nick Cleveland
This is a picture of my model mesh at the last timestep (of this run). Do I need GGI if the mesh at the interface stays lined up? (I realize now that the mesh on the horizontal FSI is not lined up, fixing that now)
Old   April 19, 2012, 13:40
Nick Cleveland
Ok, an ANSYS customer support specialist informed me that GGI is automatically activated for the FSI I have.
Please disregard any questions I just posted about activating GGI.
Old   April 19, 2012, 18:35
This is what I mean by a GGI:
Old   April 20, 2012, 07:54
Nick Cleveland
I will try that.
opening boundary motion
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Normal velocity at the symmetry boundary Seventy FLUENT 1 October 26, 2009 06:52
Help!!!: Direction / Normal of Boundary Layer JP FLUENT 0 September 9, 2008 18:16
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Warning 097- AB Siemens 6 November 15, 2004 04:41
