April 30, 2012, 09:58 |
defining-particle size distribution-in cfx
krish
Rep Power: 13 |
hello all,
i am doing two phase flow simulations in ansys cfx.while initialization of boundary conditions at inlet in particle behaviour tab..i have to mention the particle size distribution with a user specified discrete diametr distribution function.i have functions for both mass fraction and number fraction as a function of diameter. how can i insert the diameter list...? and mass fraction list & number fraction list.....as a function of diameter..? advance thanks krish |
April 30, 2012, 19:52 |
Rep Power: 143 |
This is covered in the tutorials on particle flows.
And please do not PM me when you have already posted the identical question on the forum. |
May 1, 2012, 02:14 |
#3 | |
krish
Rep Power: 13 |
can you please tell me where can i get those tutorials on particle flows...? thanks again krish |
May 1, 2012, 19:00 |
Rep Power: 143 |
The tutorials are in the help files, and the example files are in <CFX_ROOT>/examples
May 4, 2012, 05:26 |
#5 | |
krish
Rep Power: 13 |
I am getting an error while running in cfx solver.. like " wall is placing at outlet boundary " ....error is occuring some times up to 10 iterations and more..i have tried expert parameter control..artificial buid also..but no use..still getting...problem.. can any body suggest me, what it means & how can i rectify it ? (or) Does it mean that any problem while defining the physics in ccl file... (or) in geometry ? thanks krish |
May 4, 2012, 06:47 |
Rep Power: 143 |
It is not an error, it is a warning. It simply means you are getting backflow at your outlet. If it does not go away you should move your outlet downstream.
May 4, 2012, 08:37 |
#7 | |
krish
Rep Power: 13 |
" U mean that i have to extend my outlet geometry to rectify the problem...? or Can i neglect the warning and proceed my my simulations...?" and one more thing is.. i have mentioned in the previous posts about defining discrete droplet size distribution..i think you havent understand my problem properly... the point is i have data file of diameter list say for example: 10,20,30,..100 microns i want to upload this list file to the diameter list and then i have an expression for both number fraction and mass fractions as a function of diameter, for example: mf(mass fraction) (or) NF(number fraction)=Constant value(units are length)/Diameter so after uploading the diameter list and these expressions it should calculate mf and Nf values for each diameter in the diameter list so my questions are 1) how can i upload a list of values data file in to solver? 2)and how to write expressions to calculate the value for each data value in the above uploaded list ? waiting for your valuable suggestions .... thanks krish |
May 5, 2012, 07:08 |
Rep Power: 143 |
Read the documentation on this issue. But in general it is a good idea to move the boundary further down stream when this warning occurs.
It has been a while since I set particle distributions like that but I recall it can be done. Have a read of the documentation. |
size distribution |
Display Modes | |
DPM model, droplet size distribution in atomizer model | davidx | FLUENT | 3 | May 5, 2017 03:18 |
Pls help UDF about particle size (Rosin-Rammler) | ch3coohminh | Fluent UDF and Scheme Programming | 8 | January 22, 2016 09:47 |
Particle Size Distribution (PSD) in fluidization | sangramroy | FLUENT | 3 | November 2, 2011 04:19 |
particle size distribution | Bob | FLUENT | 6 | January 29, 2004 19:32 |
Particle size distribution-concentration contours | Umesh Shah | FLUENT | 3 | July 22, 2003 14:46 |
