May 13, 2012, 21:47 |
Creating Animation for FSI Modelling
Ashkan Javadzadegan
Dear all,
I did FSI modelling in an artery model and would like to create an animation of both fluid and structural parts’ results. The fluid parts’ results were saved with a time interval of 0.1s, however, the structural results were saved at all times (time interval 0.01). This means the results for 10 different times are available for fluid part, while, for the structural part, the results of 100 different times are available. I tried to create an animation and did the same settings as Oscillating Plate tutorial did, however, when I watch the movie, I just see a constant image (it seems that the animation just show the results of one time step) What I did: 1-slelect the Keyframa Animaton 2- Create Keyframe No1 and change the # of frames to 10 3- Load the first time step for fluid and structural parts. 4-Create Keyframe No2 5- Select Save movie Could you please let me know why my created animation is not like a movie, is like a constant image. Regards AshtonJ |
May 13, 2012, 23:11 |
Gwenael H.
Rep Power: 20 |
You didn't do it properly, you were nearly right.
First you should load you initial time step of interest, then >add Keyframe, change the number of frames you want, load the last time step of the animation, >add Keyframe, tick >save movie, hit the >backward icon, and then >play. |
Creating animation through TUI | wawa | FLUENT | 27 | November 5, 2021 03:17 |
how to make hardcopy only while creating an animation | yubaibai88 | FLUENT | 0 | May 31, 2010 10:35 |
Creating Animation | Umm... | FLUENT | 0 | January 16, 2008 03:23 |
!Error creating animation sequence file | Brian | FLUENT | 1 | October 21, 2005 04:35 |
Creating an animation | Jason | FLUENT | 3 | May 18, 2005 05:13 |
