CFX Solver Control, Max iteration
Like Tree1Likes
  • 1 Post By k.vafiadis
Old   May 15, 2012, 11:43
Default CFX Solver Control, Max iteration
Adil Syyed
adilsyyed is on a distinguished road
I am doing a steady state analysis.
I have given maximum iterations in solution control to be 10000 with physical timescale of 5 sec.
The solver gives me result in 55 iterations, and does not go for the whole 10000 iterations.
Why?
And before this, in the very same analysis, I just specified maximum iterations to be 1000 with 2 sec physical timescale, and the solver go up to complete 1000 iterations.
adilsyyed is offline   Reply With Quote
Old   May 15, 2012, 12:10
Erik
evcelica is on a distinguished road
Did you reach your convergence criteria? That would also stop the run.
evcelica is offline   Reply With Quote
Old   May 15, 2012, 13:06
Kyriakos Vafiadis
k.vafiadis is on a distinguished road
Send a message via Skype™ to k.vafiadis
Check what's the convergence criteria: RMS or MAX Residual Target. Also, check the way you define your Timescale.
Kyriakos Vafiadis
Mechanical Engineer, PhD candidate
k.vafiadis is offline   Reply With Quote
Old   May 15, 2012, 13:32
Adil Syyed
RMS, RMS target 0.0001
And what do you mean by he way I define your Timescale?
Old   May 16, 2012, 04:32
Kyriakos Vafiadis
A reasonable physical time scale value selection is important for good and faster convergence.
So for time scale 2sec and RMS target 10^-4 the solver needed 10000 (or more?) iterations to converge.
But with time scale 5sec and RMS 10^-4 the solver converged (converged to your RMS target) with only 55 iterations.
According to CFX Solver Modeling Guide (Chapter 14), physical time scales that are too large are characterized by bouncy convergence or results that do not converge. Time scales that are too small are characterized by very slow, steady convergence.
adilsyyed likes this.
Kyriakos Vafiadis
Problems of running Oscillating plate tutorial vovogoal CFX 20 February 4, 2016 07:03
viewing cfx post while working on cfx solver manager HMR CFX 5 March 9, 2011 22:33
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
[ICEM] trouble with mesh quality from ICEM in CFX Solver escher25 ANSYS Meshing & Geometry 0 February 28, 2011 07:38
CFX 5.5 Roued CFX 1 October 2, 2001 16:49
