May 16, 2012, 11:40 |
Moving Turbogrid mesh
Oleg
Hi guys. Does anyone know how to move turbogrid mesh?
The problem is next: I have blade geometry in turbogrid (hub, shroud, blade) and create a mesh. What i want is to parametrize the movement of whole mesh domain (translate it) along one of the axis in Workbench. I need this to simulate gradual axial clearance change between rotor/stator. Is there any possibility to do this in Workbench? TIA, Oleg. |
May 16, 2012, 18:52 |
Rep Power: 143 |
In CFX-Pre you can do simple mesh operations - move mesh about (translate, scale, rotate), copy and delete mesh regions. This should cover what you need.
May 17, 2012, 05:37 |
Oleg
Thanks for the reply, but i've already known it. The question was: Is there any way to parametrize this translation and then use it as Workbench input parameter?
May 17, 2012, 06:03 |
Rep Power: 143 |
I don't think you can parameterise CFX-Pre. You can script it, that could generate the meshes for you.
May 17, 2012, 07:04 |
Oleg
I thought so .
But any way, thanks for your time. |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
How to let the mesh motion solver just solve a small region near a moving boundary? | zhajingjing | OpenFOAM Running, Solving & CFD | 9 | April 28, 2016 04:15 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
Resisting torque on a moving mesh | floooo | OpenFOAM | 3 | March 29, 2010 20:18 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
