shock tube
hi every one.......i modeled a shock tube problem in cfx v12.1 but its results have many fluctuation.......should i give 0 [atm] for refrence pressure?
problem: air ideal gas.....high pressure:300kpa low pressure:150kpa high pressure length:0.5m low pressure length:1.5m total time:0.001 RMS Courant Number:0.01 max Courant Number:0.04 do this value for max Courant Number is Logical?? do you can explain it? thanks |
My PhD thesis has a discussion about things to consider when trying to get accurate shock wave modelling, see http://hdl.handle.net/2100/248 |
thanks a lot for replay....
You should define the reference pressure as the base pressure in the model. Search the forum for further details, this question has been asked a lot. do u can explain it for me....i solved my problem with a 0 atm refrence pressure and my results were logical when i use 1atm refrence pressure it didnt give a normal solve......what should i use for my problem as i say above Do a time step sensitivity check to establish the best time step size? how do i do it? |
Both of these questions have been asked many times on the forum. Do a search to find them.
