June 2, 2012, 04:13 |
Computational domain for a blade cascade
Alessio
Rep Power: 13 |
Hello everybody,
I am going to analyze the flow within a compressor blade passage and I know about the possibility to study a single blade, and then applying the periodic boundaries to the upper and lower side of the domain. My questions are: - which are the shapes of the surfaces on which I have to apply the periodicity? - how are these shapes affecting the results, i.e. how is the periodicity acting at the interfaces? I attach a picture of a domain corresponding to my blade geometry that I found on some articles. Thanks in advance for any help! |
June 2, 2012, 07:28 |
Rep Power: 143 |
Ideally the shape of the periodic boundary does not affect the results. There are a few pitfalls to avoid - like it should not cut through a blade (and if it has to it should do it perpendicular to the surface and not in a critical flow region), it should avoid the wake of the blade, and if possible it should avoid any shocks/rarefaction waves (but this can be very difficult to do, just minimise it as best you can).
But if you have a good mesh quality and a well converged solution you can get away with some of these sins. |
June 3, 2012, 07:43 |
Alessio
Rep Power: 13 |
Thanks for the help
Display Modes | |
Computational Domain... Help!! | devang5939 | Main CFD Forum | 0 | April 5, 2012 19:23 |
Numerical errors in nested domain with pre-calculated boundary values | Arnoldinho | OpenFOAM Running, Solving & CFD | 3 | April 4, 2012 11:31 |
[ICEM] How to mesh a 3 lenz turbine blade in rotating domain | CTan22 | ANSYS Meshing & Geometry | 13 | March 22, 2012 14:05 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 08:22 |
