June 7, 2012, 16:30 |
wall velocity in remeshing case
mahdi
Rep Power: 14 |
Dear all,
I have a problem in solving the route of body falling freely in the air. I use remeshing for simulation. When I want to apply wall velocity on the body, the solution is not impossible and causes the error. The reason is that I defined a variable for wall velocity. I think that the wall velocity can not accept variable because, when I give the expression for wall velocity there is no problem. I am forced to use variable for wall velocity. Is there any solution for it. Thanks a lot |
June 7, 2012, 19:49 |
Rep Power: 143 |
Can you explain what you are doing? What is the falling body? What path do you expect it to take? Please attach an image.
Display Modes | |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
I want to the velocity vector for the first node point to the wall. Can I use wallDis | catapult | OpenFOAM Programming & Development | 0 | January 13, 2012 09:25 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 13:11 |
UDF for wall slipping | HFLUENT | Fluent UDF and Scheme Programming | 0 | April 27, 2011 13:03 |
Problem Interface Solid Fluid with wall velocity Solver v12 | hills1 | CFX | 2 | October 12, 2009 06:36 |
