Sign of massflow across a plane
Old   June 11, 2012, 09:53
Default Sign of massflow across a plane
Chander is on a distinguished road
Hi
I have a small doubt regarding CFX-Post. If I create a plane across my domain, say Plane 1, and ask CFX post to give me massFlow@(Plane 1), then how is the sign of the resulting quantity decided?
The sign of fluxes for boundaries is clear i.e. mass flux at inlet boundary is positive and negative at outlet boundaries. This is decided by the normal of the boundary ( that points outwards og domain ) and the direction of the velocity ( outwards at outlet and inwards at inlet).
So I think the sign of a flux across any plane is also decided similarly. i.e. based upon the normal of the plane and the direction of the velocity through the plane. But how does CFX-Post decide the direction of the normal to this newly created plane?
Thanks for your inputs!
Regards,
Chander
Chander is offline   Reply With Quote
Old   June 12, 2012, 09:31
Rikio
rikio is on a distinguished road
Send a message via Skype™ to rikio
This has been explained in the help, Reference Guide > Functions in ANSYS CFX > Quantitative Function List > massFlow. "For planes and surfaces that cut through a domain, the normal of the plane or surface is determined by from the right-hand rule and the manner in which the plane or surface is constructed".
Not clear about how to use the right-hand rule. But could you tell me the meaning to know the sign of massflow?
rikio is offline   Reply With Quote
Old   June 12, 2012, 11:26
Hello Rikio,
Thanks for your response.
Actually, I was trying to find massflow through a part of my inlet boundary. While CFX post reports a positive massflow through the entire inlet boundary (as it should), it reports a negative massflow through planes that I create in CFX-Post at the location of the inlet boundary. The magnitude of massflow is ok. It is the sign that confused me. I thought that CFX would give the same sign of massflow on these planes as that on the inlet boundary.
Thinking on the same lines, how would CFX-Post decide in which direction the normal to a plane points if the plane is constructed somewhere inside the domain. As you already mentioned , the documentation seems a bit vague on this point.
Old   June 12, 2012, 21:10
Rikio
If you want to know the sign in the interior, generate a vector on the created location, and then get the sign of the plane by combining the direction of vectors. But all of these would be known after the calculation. Anyway, you can check with technical support to make it clear. :-)
Old   June 13, 2012, 04:21
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
shouldn't it follow the direction of flow? obviously at each location it checks the inlet and then finds the direction of flow through that plane.
Far is offline   Reply With Quote
Old   June 13, 2012, 19:01
Nope. It does not seem to do that. I will check with Ansys support.
Thanks rikio and Far for your replies.
Old   June 14, 2012, 03:36
Far
Sijal
You can try the mixing elbow problem to clarify the things.
https://www.sharcnet.ca/Software/Flu...btg/flwbtg.pdf
cfx post
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Problem with Sampling plane Chander CFX 10 February 20, 2012 16:57
MassFlow Function? Absolute MassFlow? Failure in Caclulation eRzBeNgEl CFX 0 May 5, 2011 09:46
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
Massflow rate/area on section plane?! Maddin STAR-CCM+ 13 August 3, 2009 08:54
