June 14, 2012, 16:03 |
stirred vessel
francesco
hi all,
i'm new with cfx and i'm trying to simulate a multiphase liquid-liquid stirred tank. i began with a simple single phase model, but the solver fails because it finds a non zero normal component of the velocity of the rotating mixer shaft. this is due, I think, to the low quality triangular mesh of the shaft itself, which doesn't reproduce the curvature of the cylindrical element. Is there any mesh method to overcome this problem? i tried to convert the 3 node surface tri element with a 6 node surface element, but it seems that ICEM can't generate the volume mesh elements. I've attached the icem cfd file. Anyone can help me? Best Regards, Francesco |
June 14, 2012, 19:15 |
#2 | |
Rep Power: 143 |
CFX (or just about any other CFD solver) cannot use "high order elements" like FEA does, so forget about the 6 node surface elements. Finite volume CFD solvers put the high order numerics in the discretisation scheme, not the element formulation. |
anyone simulated problem of Stirred Vessel using STAR-Design @ STAR-CCM+? | Miqi Cornholio | Siemens | 0 | August 19, 2009 21:19 |
stirred vessel simulation | selvam R.P | CFX | 0 | December 23, 2005 08:16 |
Mesh problems for a stirred vessel with baffles! | UY | CFX | 0 | September 14, 2005 10:19 |
Tracer problem in stirred vessel | UW | CFX | 0 | July 25, 2005 22:23 |
CFD-simulation of a stirred vessel | Peter | FLUENT | 5 | February 1, 2000 05:51 |
