Direction of Rotation of Radial Turbine
Old   June 25, 2009, 08:01
Default Direction of Rotation of Radial Turbine
ghoshi1983 is on a distinguished road
Hi everyone,
I want to do 2D simulation of Radial Turbine and want to change the direction of the rotation of my radial machine. i tried to do that by putting negative value for angular velocity in Pre processor. But didn't work out for me. Since i
am interested in Anti-clockwise roatation of impeller and It always show clockwise rotation in Post processor.
Any suggestion would be great in this concern.
ghoshi1983 is offline   Reply With Quote
Old   June 25, 2009, 09:21
Matthias Voß
mvoss is on a distinguished road
did this ages ago..
isn´t there smth- like counterrotating domain?
neewbie
mvoss is offline   Reply With Quote
Old   June 25, 2009, 18:44
Don't you just have to reverse the direction of the rotation vector? If the vector was 1,0,0 then it becomes -1,0,0.
Old   June 26, 2009, 06:18
Mehul
Mehul157@yahoo.com is on a distinguished road
If you really want to see the results of clock and anti clock rotational effect. Then you please do a transient simulations, save .trn files and postprocess them all and make the movie of your results. It will show you the things you want to see
Mehul157@yahoo.com is offline   Reply With Quote
Old   June 26, 2009, 06:40
Thanks for the replies
But still it didn't work out.
As for counter-rotating option, i don't have counter-rotating wall i have everthing moving as one body.
And as for vector values, Actually i didn't understand what you want to say.
Atif
Old   June 26, 2009, 06:53
Hi Mehul,
Thanks for the reply but i don't want to see the effects of both i just want to change the direction to anti-clockwise.
Old   June 26, 2009, 07:18
The counter-rotating option is for rotating frames of reference. You set a wall which is stationary (in the absolute frame of reference) to be a counter-rotating wall in the rotating frame. It has nothing to do with what ghoshi is talking about.
The way to reverse the rotation is to reverse the rotation vector. You set a rotation for the rotating frame of reference. It was either a coordinate axis or a vector (eg 1,0,0). Either way just reverse the rotation vector (ie if a coordinate axis then +x becomes -x or if vector +1,0,0 becomes -1,0,0) and then the thing is rotating the other way.
Old   June 27, 2009, 08:03
Hi Glenn,
Thanks for the reply it worked out for me. It just changed the coordinate axis sign.
Old   June 19, 2012, 10:16
Default Contra rotating rotor simulation using mixing plane method
venkatesh
venkat_aero2007 is on a distinguished road
Hi everyone,
I am trying to simulate flow around Contra rotating rotor using mixing plane method. I have some doubt in defining boundary condition on rotor blade.
I defined Front rotor and Second rotor as Stationary wall.
Front rotor is rotating in Counter clock wise direction (according to Right hand thumb rule). So i define the fluid in the Front rotor region as Moving reference frame which rotates about X- axis (1 0 0) at -1800 rpm (negative sign for Counter clockwise direction), Relative to Cell zone:- absolute.
The second rotor rotates in opposite to that of Firs rotor about X-axis (1 0 0) at 1800 rpm (Positive sign for clockwise direction). relative to cell zone: Opposite to front rotor Fluid
When I check the Relative velocity vector, The Direction of the relative vector for the front rotor is along Counter Clockwise direction which is wrong ( it should be in clock wise direction because of the fact that the blade rotates in counter clock wise direction) but the relative velocity vector for the second rotor looks perfect.
Please can someone help me to define the proper boundary condition.
thanks in advance for your information,
Venkatesh
venkat_aero2007 is offline   Reply With Quote
Direction of rotation Gab CFX 6 November 16, 2017 16:19
Axial Thrust in a Radial Turbine Amit Roghs CFX 3 May 31, 2010 16:47
How to change direction of rotaion of Radial Mchine ghoshi1983 Main CFD Forum 0 June 24, 2009 11:43
Radial Direction contours Felix CFX 0 September 24, 2007 09:15
Regarding the rotation direction HSeldon FLUENT 2 October 9, 2006 03:30
