June 17, 2005, 12:49 |
Thrust calculation
I simulated the operation of a small engine with an inlet, a combustor, and an outlet. The engine is sitting on the ground so the thrust is static. I monitored the average velocity-u and mass flow rate at the exit. At the inlet, velocity and mass flow rate is known constant. Thrust is calculated from momentum force only: (mdot* mass flow rate) @ outlet ¨C (mdot*mass flow rate) @ inlet. If the exit velocity is sometimes negative (opening boundary), is this still right? (negative exit velocity*negative exit mass flow rate=positive thrust, which is not phyisic)
Is there a more accurate way to calculate thrust in this case? Thanks. |
June 17, 2005, 12:52 |
Re: Thrust calculation
sorry, the thrust is (mdot*velocity) @ outlet -(mdot*velocity)@ inlet. where mdot=density*area*velocity
July 5, 2012, 16:53 |
Ajinkya Desai
Rep Power: 13 |
hey, I am simulating an oscillating/flapping fin in FLUENT. I plotted the cd vs the flow time and if the time averaged Cd comes out negative then it amount to a net THRUST rite? I need to know if this is the best way of calculating thrust. Also i should tell you, that for this oscillating fin, the average drag is coming out positive, contradictory to our hypothesis. Some one please help me with this.
Thank you. |
July 5, 2012, 18:24 |
Rep Power: 143 |
Try the fluent forum.
July 9, 2012, 11:48 |
In the report of the CFFX solver, you see the forces and moments at walls, try to look at them.
You can define a Result vector from this report and you will have the real force!! Good luck! |
MRF and Heat transfer calculation | Susan YU | FLUENT | 0 | June 2, 2010 08:46 |
calculation of thrust thrugh a pipe with CD nozzle | izhar | Main CFD Forum | 0 | February 28, 2009 09:22 |
Thrust value, positive or negative? | Emmanuel | FLUENT | 0 | June 25, 2007 19:47 |
3D Ejector Thrust Calculation | Emmanuel | FLUENT | 0 | April 6, 2007 13:59 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
