March 14, 2014, 01:12 |
a problem about the interface in CFX
wujun
Rep Power: 13 |
hi, I habe a problem about the interface in cfx,the error messages as follow:
no control surfaces have been found at all for Domain Interface 2- | | . To work around this please set the expert parameter "ggi permit | | no intersection = t" . Hope someone can solve the problem. |
March 14, 2014, 05:03 |
Rep Power: 143 |
The error message says exactly what the problem is. Your interface has no connection so is not an interface. If you are doing a transient simulation and the intention is to open an close an oriface then this is fine and use the expert parameter discussed. If this is not intentional then you will have to inspect your geometry and make the two parts of your interface line up.
March 14, 2014, 20:37 |
wujun
Rep Power: 13 |
thanks,the matter was solved.
Display Modes | |
convergenceof natural convection prob. in cfx | cpkewat | CFX | 15 | January 31, 2014 07:29 |
CFX parallel hp MPI problem | fluidmechanics | CFX | 5 | June 19, 2013 20:05 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 20:42 |
CFX Casting problem: Can it be done all in one? | jfasl | CFX | 1 | September 14, 2010 04:14 |
CFX GGI Interface Error (non-overlapping) | surge519 | CFX | 1 | August 3, 2009 19:54 |
