automatic way of calculating actual heat transfer coefficient |
August 20, 2009, 08:38 |
Syed Mushahid Hashmi
Rep Power: 16 |
the variable named "Wall heat transfer coefficient" uses near wall temperature which is not the bulk temperature of the fluid.
In a wall bounded flow is there a way to calculate the correct local bulk temperature automatically as well as the local wall heat transfer coefficient? (setting tbulk for htc dont work for local bulk temperature) thanks in advanced Hashmi |
August 20, 2009, 18:44 |
Rep Power: 143 |
By default it calculates a local bulk temperature and wall HTC. You can activate an expert parameter to define a fixed bulk temperature if you like.
Also bear in mind that the HTC returned by the solver is calculated from the wall heat transfer. That means from the wall heat transfer variable if you don't like the bulk temperature it used you can recalculate it based on whatever bulk temperature you like. |
August 23, 2009, 09:00 |
Rep Power: 16 |
Thanks Glenn Horrocks for the reply.I know wall heat transfer is a local variable, but in wall bounded flows the bulK temperature is also a variable, I mean in the pipe flow it changes along the length of the pipe, So for calculating actual local heat transfer the fixed value of bulk temperature is of no use.
In simple geometries like pipe, one can do it manually in excel by exporting velocity and temperature field but for complex geometries this is a cumbersome process, and there are not much nodes as well in complex geometries at one cross section along the flow. I am interested in some automatic way of calculating the actual heat transfer which is based on local bulk temperature. Hashmi |
August 23, 2009, 18:36 |
Rep Power: 143 |
There is no universal way of doing this. In fact as soon as you start using an arbitrary definition for the bulk temperature then there is little point in using convection coefficients and you should consider looking at the heat transfer calculated directly - which is how CFX calculates the wall heat transfer in the first place.
So I doubt you are heading in a useful direction by attempting to do a better definition of the bulk temperature. |
July 26, 2012, 06:54 |
#5 | |
Goutam Saha
Rep Power: 14 |
I am considering a pipe flow simulation. L=1.2m, R=0.05m, Re=300, Umean=0.047157m/s at T=300K.Parabolic velocity profile at the inlet, no-slip Bcs at the wall. Inlet T=300K, wall T=315 K. I have calculated U and T and it gives me the correct results but Nu is 2.5 (Actual value is 3.66). COuld you please help me. How I will do this manually in excel? Thanks for your time and cooperation. |
Heat transfer coefficient - what is waht | Stan | FLUENT | 28 | December 29, 2021 16:29 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
No results for solid domain | Gary Holland | CFX | 10 | March 13, 2009 03:30 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
