July 28, 2012, 09:10 |
About the CFX-Solver in batch mode
Shuai Shao
Rep Power: 14 |
I run a simulation case with the CFX-Slover GUI, then it worked well, without error. Because I want do an optimization, so I have to run the cfx5solve in batch mode, then an error occured as follows:
Capability CFX_SOLVER_PHYSICS_MODULE does not exist in the ANSYS licensing pool. None of the products enabling this capability are available in the specified lic ense path: ANSYSLI_SERVERS: 2325@Eric-PC FLEXlm Servers: 1055@Eric-PC I used the same def file, so there is nothing wrong with the def file. And i also checked the ANSLIC_ADMIN, three "running". I hope people who did the similar job could help me figure out this problem, and thanks a lot. |
July 29, 2012, 07:21 |
Rep Power: 143 |
The licensing is the same regardless of how CFX is started. It sounds like you have processes which have not closed properly so licenses are not freed up for the second run.
batch, cfx-slover, cfx5slove |
Parallel Fluent Error in Batch Mode | Justin | FLUENT | 3 | November 28, 2016 10:50 |
Error in CFX Solver | Leuchte | CFX | 5 | November 6, 2010 06:12 |
How to batch run CFX 11 solver on Win XP | James | CFX | 8 | July 10, 2008 11:57 |
fluent stops batch mode on error | Ralf Schmidt | FLUENT | 1 | March 1, 2008 10:35 |
problem in CFX solver about isolated volumes | Yuan | CFX | 2 | August 16, 2004 22:54 |
