August 13, 2012, 21:48 |
Questions about cfx
Stefan
Rep Power: 13 |
Hi.
There is a question with the gear pump. When the inlet was set as 0MPa, and massFlow at outlet(pressure was set 0MPa) was 2.4kg/s. However, when the pressure at outlet was set 5Mpa,the massFlow at outlet was nearly 1.2kg/s. So this is consistant with the real situation,or something is wrong with my setup. I did this simulation with the method of Immersed Solid in CFX. thanks! |
August 14, 2012, 08:00 |
Rep Power: 143 |
I do not know what you are modelling in detail so cannot say for sure, but your results could be possible. You get 2.4 kg/s flow with no pressure gradient, and when the pump is pushing against a 5MPa pressure the flow rate slows to 1.2kg/s. With a positive displacement pump like this the loss in flow is presumably due to fluid leaking around the impeller.
August 14, 2012, 10:12 |
Stefan
Rep Power: 13 |
It is my model.
August 14, 2012, 10:20 |
Stefan
Rep Power: 13 |
At the very beginning, I thought it is the problem of leakage.But the radial gap, axial clearance and gear backlash were all set zero.When I set outlet 20MPa,the massflow at outlet was 0kg/s,also the pressure at inlet was 8MPa, while the toal pressure at inlet I set before was 0MPa.
So I can't figure out the problem . my model? mesh size? |
August 14, 2012, 19:17 |
Rep Power: 143 |
Don't forget immersed solids work by using a scaling factor on a momentum source term. Flow will slowly filter through the solid region if that factor is not set high enough. Have you done a sensitivity analysis of the factor?
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Different flow pattern between OpenFOAM and CFX | AirS | OpenFOAM | 0 | January 12, 2010 07:08 |
heat generation in CFX | Ema | CFX | 4 | August 7, 2009 05:39 |
CFX 10's solutions differ from CFX 5.7's | Atit Koonsrisuk | CFX | 4 | July 26, 2006 11:59 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
