Oscillatory flow 101
Old   August 22, 2012, 08:11
Default Oscillatory flow 101
Andris is on a distinguished road
Hi all,
I am using CFX to model oscillatory flow in a bifurcation. BC's are inlet with a velocity defined by a trigonometric expression that I entered, outlet with a relative pressure of 0 and wall with no-slip condition. Initial values are zero for all velocities. Transient flow has been selected, and output control to print results every second.
The mesh is a simple octree mesh.
This is a simple situation but it just simply does not work, I was wondering if I am missing something obvious?
Any help would be greatly appreciated,
Andris
Andris is offline   Reply With Quote
Old   August 22, 2012, 08:33
Lance
Lance is on a distinguished road
besides describing what it is that doesnt work? We cant help you if you dont give us any more info...
error messages? ccl? solver output?
Lance is offline   Reply With Quote
Old   August 22, 2012, 09:24
Hi Lance,
here is the error message
An error has occurred in cfx5solve:
writemms exited with non-zero return code 11
I was wondering if this transient problem has to be done in a similar way to as it is done in the tutorials, i.e. taking initial conditions from a steady state domain?
Old   August 22, 2012, 09:38
Here is the geometry I am using,
I readjusted the global initialization to a very small velocity in the y direction,
I get the following error message
ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Floating point exception: Overflow |
| Message: |
| Stopped in routine FPX: C_FPX_HANDLER |
Old   August 22, 2012, 10:16
Lance
http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F
Old   August 22, 2012, 10:21
thanks for the link, instead of using an expression, I used an excel file, and got a solution, though the solution was very very bad, I am surprised it worked
Non-steady flow simplified for use in Vissim steamerandy Main CFD Forum 0 October 31, 2011 21:08
Fully Developed Flow in Star-cd SMM STAR-CD 0 September 5, 2011 22:08
Help on laminar oscillatory channel flow [Help needed - Urgent] Dtkcby Main CFD Forum 0 March 19, 2011 15:11
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
Boundary Layer Flow Paradox Wen Long Main CFD Forum 3 September 24, 2002 08:47
