outlet conditions
Old   August 27, 2012, 05:34
Default outlet conditions
henry
h-banana is on a distinguished road
hey im new to CFX and am just starting a project at a new company where i am looking at two phase flow, water particles in air through a vane/vent type enclosure.
i am having problems with my outlet conditions, is it possible to not have to input and conditions here, I have tried just setting the static pressure but this puts up a wall which restricts flow, setting a velocity changes the flow through the vent.. I also tried using an opening as opposed to an outlet but it crashed every time. Not sure If theres probably a very simple solution to this problem.??
h-banana is offline   Reply With Quote
Old   August 27, 2012, 07:39
bratzinger is on a distinguished road
Hi
i would enlarge the outflow region and evaluate the plane where your former outlet region was or evaluate a bit downstream
otherwise the results could be compromised because the outlet condition forces the eddy to end upstream(noticed that in an OpenFOAM-case with outlet-condition) or you could have problems with convergence(my experience with a heatflow analysis in an Ansys-case where i tried to set the inflow-temperature of the opening-condition with an massFlowAve(T)@outlet-expression) and maybe the missing convergence causes the solver to crash in your case
bratzinger is offline   Reply With Quote
Old   August 27, 2012, 07:55
Can you post an image of what you are modelling and the flow applied to it?
Old   August 27, 2012, 21:03
henry
this is the mesh, I need to model the water particles track where they become trapped in the grooves of the vent.
Old   August 28, 2012, 07:23
If the flow is high Re then your exit boundary is too close. You need to move it downstream - bratzinger's comment is correct.
cfx, outlet boundary condition
Boundary conditions: inlet and outlet aline OpenFOAM 7 June 29, 2010 03:45
Inlet & Outlet Boundary Conditions dhananjay Main CFD Forum 2 December 21, 2006 10:03
outlet conditions tzapelina Phoenics 3 January 16, 2004 04:07
Impinging Jet. Outlet Boundary Condition Vincent Main CFD Forum 0 December 16, 2003 10:49
Outlet vent boundary conditions Ignacio FLUENT 2 August 30, 2001 04:43
