Courant number and timestep query
Old   August 30, 2012, 07:08
Default Courant number and timestep query
siw
Stuart
siw will become famous soon enough
I understand from ANSYS tech support that for a transient (SAS-SST) CFX simulation (for an external transonic aerodynamics simulation) that the maximum CFL number should be <= 5.
So in order to estimate an appropriate timestep (dt) using:
CFL = (u * dt) / (dx) <= CFLmax
what values should be used for u and dx? Can u be the fresstream velocity? Since the mesh has a wide range of cell sizes should dx be the cell size where the most interesting physics occurs - in my case the wake behind a bluff body? Once I get a timestep I can then use that as a start for assessing timestep sensitivity on the simulation.
Thanks
siw is offline   Reply With Quote
Old   August 30, 2012, 08:11
Lance
Lance is on a distinguished road
Please correct me if Im wrong, but I think that u is the velocity in each cell and dx would be the cube root of the cell volume. Dont know if you need a CFL number < 5 in the entire flow domain, but certainly where all the action is.
Lance is offline   Reply With Quote
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
Running stably with a large Courant number using pimpleFoam mlawson OpenFOAM 11 November 29, 2014 10:37
Problems With courant number Icofoam basilwatson OpenFOAM Running, Solving & CFD 0 May 21, 2011 09:39
courant number for hvac simulation Chilli83 CFX 1 May 5, 2009 20:39
