free surface model
Like Tree1Likes
  • 1 Post By ghorrocks
Old   September 5, 2012, 00:07
Default free surface model
leo
sjtusyc is on a distinguished road
1)When we do multi-phase simulation, in the Fluid Model Tab,we have to specify whether it is a standard free surface model or not.
I am a little confused about this setting,when should we chose the standard free surface model option.What will it determine,say,the governing equation?Does it equal free surface flow?
2)For problems that the interphase between the two phases is well-defined,i will chose the homogeneous model and free surface model as recommended by the help.If we chose the homogeneous model,the one bulk N-S equations is determined,why we need use free surface model.
These questions seems silly,but i hope someone would shed light on it .
Thanks.
sjtusyc is offline   Reply With Quote
Old   September 5, 2012, 06:25
1) This determines whether the free surface sharpening stuff is turned on, and other options such as surface tension. You should choose the free surface model when you intend to resolve the free surface in your simulation. If you want the interface to diffuse then leave it off.
2) See above answer.
Danial Q likes this.
Old   September 5, 2012, 06:44
leo
Thanks for your reply.
So, the free surface model is used to turn on the free surface sharpening stuff, like the VOF method,to get reasonable interface.
But , as i know,a complete physics question consists of the governing equations and the boundary condition. So why need free surface sharpening stuff? Why we need the reynolds
transport equation of F(volume of fluid).
Old   September 5, 2012, 18:33
We need free surface sharpening because otherwise it will diffuse. And you need a volume fraction equation as the volume fraction convects with the flow.
There other approaches of modelling free surfaces, but the volume fraction with free surface sharpening is the one implemented in CFX.
MULTIPHASE - FREE SURFACE & MIXTURE MODEL Aris FLUENT 3 April 28, 2009 11:46
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
gravitational force for free surface flow Jongtae Kim Main CFD Forum 1 July 2, 2000 11:57
Variable Density - Free Surface with FIDAP Vitaliy Pavlyk FLUENT 7 May 2, 2000 15:56
free surface model of pelton turbine bucket Mark Jones Main CFD Forum 0 April 10, 2000 08:20
