September 10, 2012, 04:12 |
CFD-post
leo
Rep Power: 13 |
I did a spray simulation and wanna to get the Sauter Mean Diameter and diameter distribution at a specified area.
I read the documentation and do the tutorials ,but still can not find it . Does anyone know how to achieve this. Thank you. |
September 12, 2012, 04:13 |
leo
Rep Power: 13 |
Does anyone know about this ?
September 12, 2012, 08:12 |
Rep Power: 143 |
This is straight forward post processing. The SMD is a standard variable for apropriate multiphase simulations, so just plot the variable on the object you like. Or do a CEL expression on it, or what ever you want.
September 12, 2012, 08:29 |
Max
Rep Power: 14 |
This should not be too hard to do with CEL expressions.
If you really want to calculate it for a specified area, that means you want something like a 2D sauter diameter, right? So particle area / interface length instead of particle volume/ interfacial area. My idea for that would be to simply integrate the volume fraction over the area. That gives you the particle area (corresponding to the volume in 3D). To get the interface length (corresponding to the interfacial area in 3D) you could plot a contour, insert a polyline at a suitable contour level and then get the length of this line via CEL. For a real 3D case you could use isovolumes and isosurfaces to get the volumes and surfaces of the particles. EDIT:Or you could just use the SMD variable that Glenn mentioned and that I did not know about |
September 13, 2012, 09:50 |
#5 | |
leo
Rep Power: 13 |
I only find the averaged Sauter Mean Diameter in the variable list. But if i want quantitative analysis,like: 100-120um ??% 120-140um ??% |
CFD Design...The CFD Future | John C. Chien | Main CFD Forum | 20 | November 19, 2015 23:40 |
CFD post, expressions help | robcowlam | FLUENT | 0 | February 21, 2012 14:14 |
CFD post vector plot problem | bharath | CFX | 3 | February 8, 2011 17:16 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
post processing in CFD | MANISH BHARGAVA | Main CFD Forum | 0 | October 17, 1998 20:51 |
