Discharge coefficient in function of pressure ratio |
September 21, 2012, 05:36 |
Roland Rakos
Rep Power: 17 |
I calculated compressible high speed flow in steady state. I determined the discharge coefficient from the results in case of some pressure ratio (pi = 0.6 - 0.125). Based on my calculations, the discharge coefficient is constant in this range. (alha = 0,85) The discharge coefficient was investigated at the full geometry. What do you think about this? Can it be correct? Is there pressure ratio range where the discharge coeff. changes in the function of pressure ratio? Thanks Roland |
September 24, 2012, 21:58 |
Rep Power: 143 |
Discharge coefficients can be either constant over pressure ratio or variable. It depends on the details of the set up.
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Total pressure to static pressure ratio | roadracer | Siemens | 1 | April 17, 2003 05:31 |
