I have a small problem with transition model Gamma-Theta combined with SST to analyze the flow around a cylinder. Since the surface of cylinder is rough, it's needed to define "Sand Grain Roughness Height". But this is a straightforward problem cause I know the roughness on the surface. When I give a value for "Sand Grain Roughness Height", it's recommended to specify a Roughness Correlation in the Gamma-Theta model. I wonder what is "Geometric Roughness Height" in "Roughness Correlation", and how we can calculate it based on "Sand Grain Roughness Height". Does anyone give me some ideas? |
Rep Power: 145 ![]() ![]() ![]() ![]() |
This is pretty specialised stuff - I would read the original references papers on this model to know how to approach this.
I've read documentation provided in CFX. The model is mentioned in the documentation, but nothing is more than that. Concept "Geometric Roughness Height" in "Roughness Correlation" is a specific concept of CFX, not of the original model.
I wonder to know what it is. |
Bruno
Rep Power: 22 ![]() |
The roughness height alone is not enough because you can have different types of morphologies making up the roughness, that is, roughness shape and density also play important roles in determining how wall roughness afects the boundary layer.
The documentation has a reference that shows how you correlate both types of roughness, but I think it it all comes down the nondimensional roughness you use on the Moody Chart for estimating pressure drops on pipes. Cheers |
Bruno
I just read your question again and realized I was answering a different question. But it still somewhat applies. The referenced paper shows how sand grain equivalent roughness is calculated from the original roughness' height, shape and density, so maybe you can revert the calculations to estimate your surface height.
Still, my guess is that, if you don't know roughness shape and density, retrieving its height won't be straightforward. Please share your findings afterwards. Cheers |
Display Modes | |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 13:57 |
transition in SA turbulence model | wassim | FLUENT | 4 | October 14, 2004 13:01 |
model transition | nico | FLUENT | 0 | February 8, 2004 09:04 |
Transition Modeling using CFX4.2 | Athar | Main CFD Forum | 1 | November 24, 1999 15:02 |
k-omega model and unsteady transition | Jens Thurso | Main CFD Forum | 1 | May 4, 1999 09:50 |
