Material Properties table? (function of two variables) |
October 1, 2012, 16:29 |
Erik
Rep Power: 23 |
I'm doing some simulations with seawater and the material properties will be functions of both Temperature and Salinity I have tables with the material properties, but am wondering if it is possible to insert them as a table of some sort.
I can create a mathematical function of two variables but this is kind of a pain and inserting a table would be much easier. |
October 1, 2012, 19:02 |
Rep Power: 143 |
You might be able to use a 3D interpolation function to do this. Just keep the third dimension as zeroes.
October 1, 2012, 19:36 |
Erik
Rep Power: 23 |
That's what I was thinking, but when I looked at it the argument units had to be the same for each of the 3 dimensions. I guess this wouldn't matter If I just gave salt content a false temperature unit. That would probably work fine then, Thanks.
I've settled on just using several 1D interpolation functions, and I will just have to change them manually according to the salt content, which won't vary in each simulation. I didn't know if there was an easy straightforward way to do this or not, and figured it might be helpful for future materials that depend on two variables. Thanks again, Erik |
compressible flow in turbocharger | riesotto | OpenFOAM | 50 | May 26, 2014 01:47 |
Material Properties for Sat. Liquid and Sat. Vapor | Blackhawks84 | FLUENT | 0 | September 17, 2012 19:11 |
Defining non-constant material properties | Scott | CFX | 7 | August 8, 2008 17:35 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 06:27 |
PHI file structure | Eugene | Phoenics | 9 | November 2, 2001 22:00 |
