October 3, 2012, 23:20 |
Can anyone help me of using K-Epsilon
Hope
Rep Power: 13 |
When I use the K-Epsilon in CFX, the result is strange. My first node is 2e-7 m from wall. After exporting the result, I find that V(y=0)=0, V(y=2e-7)=5, it's almost half of the highest one. The velocity is growing too fast. Can anybody tell me that how can I fix that? Thank you Hope |
October 3, 2012, 23:33 |
Hope
Rep Power: 13 |
Basically my problem is the hybrid and conservative are same expect the wall velocity. And the velocity grows too fast.
Could anyone help me and tell me how to fix that? Thank you! Hope |
October 4, 2012, 07:40 |
Rep Power: 143 |
The parameter you want to look at is y+, the non-dimensional distance from the wall. The distance of the first node does not mean anything by itself.
And why do you say the velocity grows too fast? Do you have analytical or experimental results to show it should be slower? |
October 4, 2012, 08:15 |
#4 | |
Hope
Rep Power: 13 |
What's y+? my width is about 0.1m, and the first node is at 2e-7 m. Yes, I have experimental results. my case is a wind tunnel, velocity inlet, pressure=0 at outlet, and non-slip smooth wall. Look my attachment. The green one the experimental results, and red one is my result. at the very beginning it grows too fast. but it's better on the second node. And I don't know why. |
October 4, 2012, 11:50 |
Erik
Rep Power: 23 |
Like Glenn said, plot your "y plus" (not solver y plus) for the wall. I'm guessing it is below 11 and k-epsilon is using wall functions to approximate your wall improperly since the y plus is too small.
I'd recommend switching to a different turbulence model that will fully integrate the walls, like SST. Try to get your "y plus" values below 1 if you are trying to compare the boundary layers near the wall, you only use wall functions when you don't care much about the boundary layer. This is pretty basic, CFD 101; Your homework: Read Chapter 4 of the CFX solver modeling guide "Turbulence and Near-Wall Modeling" Last edited by evcelica; October 4, 2012 at 11:53. Reason: This is pretty basic, CFD 101; Read Chapter 4 "Turbulence and Near-Wall Modeling" |
k-epsilon cfx |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 16 | March 4, 2017 08:30 |
Large Epsilon 3D | lepsilon | Main CFD Forum | 0 | July 10, 2012 10:43 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
How to get reference to k and epsilon in the epsEqn and kEqn | cfd_explorer | OpenFOAM | 0 | March 10, 2011 09:58 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 1 | November 25, 2008 20:21 |
