Shear stress in perforated pipe for horizontal wells
Old   October 12, 2012, 17:24
Default Shear stress in perforated pipe for horizontal wells
Mohammed
mohw2002 is on a distinguished road
I am working on the wellbore (perforated pipe) for horizontal wells. I want to calculate the shear stress tau w and friction factor f from CFX.
mohw2002 is offline   Reply With Quote
Old   October 13, 2012, 03:27
S.Bogoda
sakurabogoda is on a distinguished road
As far as I know, it is not easy to find friction factor by CFX as when you model it you should input stream-wise and transverse loss coefficients. Without knowing them you cannot model it. So better to do a simulation or get experimental data.
Pls. this is according to my knowledge and experiences.
sakurabogoda is offline   Reply With Quote
Old   October 13, 2012, 05:32
What friction factor are you looking for? There are many definitions of it.
Wall shear stress is easy to extract - is this what you mean by shear stress tau w?
Old   October 13, 2012, 10:28
Mohammed
Hi ghorrocks.
I mean how can I calculate the shear stress inside the pipe wall due pressure drop due to wall friction and then calculate friction factor f for turbulent flow. I am using CFX k-epsilon model.
Regards.
Old   October 13, 2012, 10:31
Mohammed
Hi Sakurabogoda.
How can I input stream-wise and transverse loss coefficients.
Regards.
Old   October 14, 2012, 04:13
Getting the wall shear stress is simple, it is a variable in the results file by default. Then you just need to get an average of it at the representative point along the length, and you can get the pressure drop from that. This is all pretty standard post-processing.
Sorry, what is stream wise and transverse loss coefficients? How are you defining these terms?
Old   October 15, 2012, 00:54
S.Bogoda
When you do a porous or perforated design, you have to input directional losses; streamwise and transverse. Both are related to pressure drop and transverse loss can be take in terms of Streamwise coefficient. That is why I told to do simulation or experiment, to get pressure drop.
Dear Glenn,
I am doubt about how to get pressure drop by CFX without knowing directional losses. I would really appreciate your advice.
Old   October 15, 2012, 02:52
Mohammed
Dear Glenn,
Dear sakura
Sorry how can I do to input directional losses; streamwise and trasverse by CFX? I mean where? do you have toturial about this?
Old   October 15, 2012, 04:20
S.Bogoda
Dear Mohammed,
Refer "Flow in a Catalytic Converter" in tutorial manual. It is about a porous domain, but you can get an idea how to modify it into your model.
Old   October 15, 2012, 05:22
Assuming you have a normal fluid domain (not a porous domain) then can't you simply put a series of points (or maybe a line) along the centre line of the pipe and monitor points at the periphery? Then your streamwise loss coefficient can be calculated from the pressure drop along the pipe, and the transverse loss can be calculated from the pressure drop from inside the pipe to outside?
This is just straight forward post-processing.
Old   October 19, 2012, 16:58
Mohammed
Hi
How can I do it at the post-processing without fix it at pre-processing?
Old   October 19, 2012, 17:06
Mohammed
Dear Mohammed,
Dear
When I consider my geometry (perforated pipe) as a Catalytic Converter I have some questions
1- There is domain named (Subtarte) but how can I put in my model like that.
2- How much the value of volume porosity?
3- Set streamwise loss which one I will choose?
4- Can I use the Quadratic Resistance coefficient or another one?
5- How much value use to the streamwise coefficient Multiplier?
thanks
Old   October 20, 2012, 05:20
This is basic post-processing. Have you done the CFX tutorials? They describe how to post process your results. Likewise your reply to Mohammed is basic CFD which is covered in the tutorials.
Old   October 21, 2012, 21:16
S.Bogoda
Dear Mohammed,
All parameters depend on your design. Read CFX theory guide and there it specified how to create the domain and loss model, with/without the effect of volume porosity.
Other setting has to be define by you. You should have a stramwise loss due to the wall shear.
Measuring wall shear stress in bend pipe liguifan OpenFOAM 70 December 9, 2015 03:49
Wall Shear Stress in a Pipe itsme_kit Siemens 4 February 11, 2012 12:32
shear stress scalar definitions? Novak Elliott CFX 0 April 6, 2003 01:45
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
What is the detail definition of wall shear stress zjm FLUENT 0 January 2, 2002 07:43
