Using Workbench, CFX-Pre doesn't update mesh from upstream data |
November 25, 2012, 11:40 |
Shawn
Rep Power: 14 |
I'm using Workbench to setup my CFX project so I've started with on CFX item. Since my mesh is similar for all cases, just different aspect ratios, and the boundary conditions are the same, I've duplicated the CFX item for as many ARs as I have. I've updated the geometry and update the mesh for each case, but for some reason the updated mesh doesn't get brought fordward into CFX-Pre - I'm still getting original mesh - even if I update or edit the CFX cell.
I can reset the CFX cell, edit it which brings in the correct mesh, and then manually set all my conditions and boundaries again. I can reset the CFX cell, edit it which brings in the correct mesh and import my original case and delete some things. I can import the update mesh manually without resetting the CFX cel, delete the original mesh and reapply boundaries to the new mesh. Or.... Is there something I'm missing so that CFX will automatically update my mesh from the upstream mesh? I haven't had this issue before, so I'm thinking maybe it's a setting that's changed? Thanks |
November 25, 2012, 12:06 |
Shawn
Rep Power: 14 |
I should also add that I'm using V14. And, when I modify my mesh, the status of the CFX cell does change to indicate that it is out of date and needs to be updated.
I tried importing the mesh manually without resetting the CFX cell. This will not work because I cannot delete the original mesh. |
November 25, 2012, 13:06 |
Shawn
Rep Power: 14 |
I found a "Reload Mesh Files" command available in CFX-Pre standalone. This is the feature to perform the task I'm looking for, however, there is a note at the bottom of the page which reads "This feature is not required (and is not available) in CFX-Pre launched from ANSYS Workbench." It would appear as though this feature is not working properly, or, it somehow got linked incorrectly. Any ideas how to re-enable it or re-link it correctly?
Also, I can perform an Export CCL command which will export my CFX setup minus the mesh (time settings, boundaries, monitor points, etc.). This seemed to work fine. I did have to redo my mesh transformations but after that all the conditions were good. |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[ANSYS Meshing] Problem in updating the mesh in Workbench | victorz | ANSYS Meshing & Geometry | 23 | October 31, 2017 02:52 |
[ICEM] issue occur after extrude 2D airfoil mesh and convergence problem in CFX | shiyun | ANSYS Meshing & Geometry | 4 | May 9, 2012 19:55 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
