May 6, 2008, 23:38 |
creat a new material -blood in CFX-pre HELP!
anybody who can tell me how to creat a material such as blood as Fixed Composition Mixture ? looking forwards!
May 7, 2008, 07:32 |
Re: creat a new material -blood in CFX-pre HELP!
Right-click on "Materials" and add new. Use this to create all the necessary components of the mixture. Then create a new mixture in the same way, but this time choose "Fixed Composition Mixture". For the components, click the button next to the components list to bring up a list of all the materials. Hold Ctrl and click on all of the components to select. Fill out all the necessary options.
May 11, 2008, 00:57 |
Thanks sincerely ! i'll try
March 29, 2012, 14:42 |
Hesam Moghaddam
Rep Power: 14 |
dear Sir,
Could you be able to create blood in CFX? could you please explain what you did and what components you took? Regards, Hesam |
January 8, 2013, 14:14 |
please help
prakash
Rep Power: 13 |
I working with ANSYS CFX. and simulating a stratified flow in straight pipe. but facing so many problem in CFX-Pre.
prob: a 44mm(id)X50 mm(od).X1000mm(L) horizontal pipe initially filled with 50 degree water and .001m/s water at250 degree start flowing in side the pipe operating pressure is 17MPa. ambient temperature in 37 degree. and heat transfer through pipe also taking place. so for steady state laminar flow simulation, what should be the 1. reference temp. ? 2. relative pressure ? 3. reference temp. ? 4.buoyancy reference temperature and Density. ? 5.static pressure.? plz help me..and repy as soon as possible.. and thanx in advance.. |
January 8, 2013, 17:13 |
Rep Power: 143 |
Please start a new thread for a new question.
only 1 of many named selections not showing up in cfx pre | mihirbhagat | CFX | 2 | April 26, 2019 04:56 |
Defining a domain in CFX Pre | ashtonJ | CFX | 1 | June 13, 2011 02:34 |
Importing a project from ICEM to CFX pre | faisal_durr | CFX | 2 | February 9, 2011 10:20 |
different CFX Pre and Post mesh region | mactech001 | CFX | 9 | April 11, 2010 21:08 |
Combatibility between ICEM and CFX pre | Vag | CFX | 1 | February 12, 2009 08:07 |
