How to fix this?
Old   January 16, 2013, 04:09
Default How to fix this?
minhhdac is on a distinguished road
i has a error: An error has occurred in cfx5solve no results has been created.
| Writing transient file 0_CS.trn |
| Name : Transient Results 1 |
| Type : Selected Variables |
| Option : Every Coupling Step |
| ERROR #002100061 has occurred in subroutine SERVE_CLIENTS. |
| Message: |
| The connection between this CFX process and an external process |
| has died unexpectedly. The following error was received: |
| External process : ANSYS |
| Error experienced : Read |
| ** This error is fatal: Terminating ANSYS CFX Solver execution ** |
| Please review the output, error and log files from both the CFX |
| and external processes to determine the cause of the error. |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
| The following transient and backup files written by the ANSYS CFX |
| solver have been saved in the directory |
| C:/Users/Admin/AppData/Local/Temp/nhe |
| 210_4732_Working/dp0/CFX-1/CFX/Work2/Fluid Flow CFX_002: |
| 0_CS.trn |
| The results from this run of the ANSYS solver have been written to |
| C:\Users\Admin\AppData\Local\Temp\nhe |
| 210_4732_Working\dp0\CFX-1\CFX\Work2\Fluid Flow CFX_002.ansys |
| The following user files have been saved in the directory |
| mon |
| Warning! |
| After waiting for 60 seconds, 1 solver manager process(es) appear |
| not to have noticed that this run has ended. You may get errors |
| removing some files if they are still open in the solver manager
help me, thank you very much!
minhhdac is offline   Reply With Quote
How to fix the temperature at the interface in VOF Was FLUENT 1 May 21, 2007 13:43
roe solver with entropy fix mehdi Main CFD Forum 1 February 26, 2006 05:36
Win XP hot fix bug!!! Emilio Siemens 1 March 27, 2003 12:06
How to change and fix the size of graphics window? Rob FLUENT 1 February 7, 2003 10:15
fix Re Fread CFX 0 July 15, 2002 04:57
