Rounding Values in Post
Old   January 22, 2013, 10:15
Default Rounding Values in Post
stifelistefan is on a distinguished road
Hi Everybody,
I'm trying to get the length of my geometry with the following expressions:
TEXT: X Abmass
Colour = 0, 0, 0
Font = Sans Serif
Position Mode = Three Coords
Text Colour Mode = Default
Text Height = 0.024
Text Position = (maxVal(X)@domair + minVal(X)@domair)/2, maxVal(Y)@domair + 2 [m], maxVal(Z)@domair
Text Rotation = 0 [degree]
Visibility = On
X Justification = Center
Y Justification = None
TEXT ITEM: Text Item 1
Auto Annotation Expression = (maxVal(X)@domair - minVal(X)@domair)
Auto Annotation File Date Format = DD/MM/YY
Auto Annotation File Time Format = h:m:s t
Auto Annotation Filename Format = Filename Only
Auto Annotation Type = Expression
Embed Auto Annotation = On
Text Item Active = On
Text String = <aa>
END
END
Unfortunately "(maxVal(X)@domair - minVal(X)@domair)" gives "33.7966 [m]"
Does anyone know how I can have it rounded to two digits? And if that's possible: to remove the units?
Thanks
stifelistefan is offline   Reply With Quote
Old   January 22, 2013, 15:39
mjgraf is on a distinguished road
Off the top of my head not sure how to do that in an expression or CEL, but the Power Syntax can easily do it.
Create a session file
2 perl lines
! ($extent, $extent_units) = maxVal("X","DEF") - minVal("X", "DEF");
! $extent = sprintf "%.2f", $extent;
Then add the CCL code for the TEXT you already provided.
On the line Auto Annotation Expression
make it
Auto Annotation Expression = $extent
Example:
TEXT:Text 1
  Colour = 0, 0, 0
  Font = Sans Serif
  Position Mode = Two Coords
  Text Height = 0.024
  Text Position = 0 , 0.96
  TEXT ITEM:Text Item 1
    Text String = Expression = <aa>
  END
END
Originally Posted by stifelistefan View Post
Hi Everybody,
TEXT: X Abmass
Colour = 0, 0, 0
Font = Sans Serif
Text Height = 0.024
Visibility = On
Text String = <aa>
END
END
Thanks
mjgraf is offline   Reply With Quote
Old   January 23, 2013, 02:32
Hi mjgraf
That work perfectly! Thanks for the quick reply!
Old   January 23, 2013, 10:21
HI again :-)
I have a new problem with probably a similar solution... (something in perl :-))
I would like to have my text position automated
is not good enough...
Is it possible that the text is right alined to the text position? And is it possible that the distance to the text position is constant (when changing the camera position in Post)?
Cheers
Old   March 5, 2014, 08:10
Zvika
benadam10 is on a distinguished road
You can use int() and nint() CEL functions
benadam10 is offline   Reply With Quote
strange node values @ solid/fluid interface - help JB FLUENT 2 November 1, 2008 12:04
node values or cell values? aPpA FLUENT 0 November 10, 2006 08:56
Plotting raw data values Wilesco Siemens 0 January 5, 2006 05:34
post processing CL values Joe Bryant FLUENT 2 October 18, 2004 04:17
Post Processing Koorosh MOHAMMADI FLUENT 1 June 13, 2002 06:54
