Question about transitional model
Old   March 3, 2013, 18:43
Question Question about transitional model
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
For my case, turbulent flow transfer to laminar in a narrow rectangle pipe. 5% of the flow is turbulent, 15% is transitional, 80% is laminar. I care about the overall total pressure drop prediction. 5% of the total pressure drop is in turbulent area. 15% is in transitional area. And 80% is in laminar area.
Shall I still use the transitional model for this case? How's the transitional model work for the laminar part of the flow? Or I'd better switch to laminar model?
Thanks!
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
Old   March 4, 2013, 04:39
The transitional model is for laminar to turbulent transition, not the other way around. The model is not suitable for your laminarisation model.
Two options:
1) Run using a turbulence model which degenerates to zero turbulence nicely, such as SST - this is a good option if the important stuff happens in the turbulent region. OR
2) Run using a laminar flow model. This is a god option if the laminar bit is most important.
ghorrocks is online now   Reply With Quote
Old   March 4, 2013, 06:31
Question
Anna Tian's Avatar
Meimei Wang
Two options:
Why the transitional model can't be used the other way around? I read the the transitional model part of CFX tutorial.
https://www.sharcnet.ca/Software/Flu.../i1324236.html
It doesn't tell that it's only for laminar-turbulent transition.
Thanks.
Best regards,
Meimei
Old   March 4, 2013, 16:45
You have to read the research papers which describe this model in more detail. The model was tuned to model lam to turb transition in airfoils and similar geometries, where the transition occurs in the boundary layer and spreads from there. It has not been tuned to handle lam-turb transition in bulk flows.
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
about Subgrid-scale model impecca OpenFOAM Running, Solving & CFD 4 December 20, 2013 10:36
k-w SST transitional model problem shanon ANSYS 0 September 21, 2010 09:00
SAS-SST and transitional model have disappeared Josh CFX 16 September 7, 2010 19:17
second and final question about flamelet combustion model AdidaKK CFX 0 October 17, 2009 07:25
