December 6, 2018, 03:09 |
Courant Number
Pedro Oliveira
Rep Power: 8 |
I know that Courant number should be near 1 to calculate a viable solution, but even with a 999 Courant number, my smulation converges.
Should I work with Courant numbers near 1, which will imply a timestep 1000 smaller, or if the solutton converges, it doesn't matter? Best regards! |
December 6, 2018, 04:21 |
urosgrivc
Rep Power: 11 |
it depends on the case if it is ok or not.
it doesn't need to be 1 Mosty depends on vhat phisics you are simulating Your solution must be timestep size independent, try different timestep sizes and check your results if these are very different than something is not ok and the solution is not independent. And courant number as it is, has to be understood properly, what I mean is, let say you want this number to be 1 well then you can either decrease the timestep or aparently increase the mesh size, the coarser the mesh the lower the courant number, but is this a solution or just a unimportant idea? well, that is up to the user to decide... https://www.sharcnet.ca/Software/Ans.../i1313549.html https://www.sharcnet.ca/Software/Ans...fxBasiVariCour Last edited by urosgrivc; December 6, 2018 at 05:52. |
December 6, 2018, 04:40 |
Rep Power: 143 |
The Courant number 1 criteria is a hard limit for explicit solvers. If you exceed this the solver will diverged, guaranteed. But it is a common mistake to think this criteria also applies for implicit solvers like CFX. This is why you have got convergence at high Courant numbers, Courant number is not a criteria of much significance for implicit solvers.
You really should ignore the Courant number for CFX. The way to determine time step size for implicit solvers like CFX is to do a sensitivity analysis on the time step size.
December 7, 2018, 03:09 |
Pedro Oliveira
Rep Power: 8 |
Thank you so much for your replys, they were both very helpful.
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
multiphaseEulerFoam (OF2.3.0) : Courant number explodes when running in parallel | Mehrez | OpenFOAM Running, Solving & CFD | 10 | May 18, 2016 11:44 |
Sudden jump in Courant number | NJG | OpenFOAM Running, Solving & CFD | 7 | May 15, 2014 13:52 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
