Return with error code 1
Old   March 30, 2013, 08:11
Default Return with error code 1
Darázs Bence
darazsbence is on a distinguished road
Hi Everyone,
I have a problem concerning error code 1 and don't know what to do. I would like to continue a SST run with and SSG so when I define my new run I select the . def file of the SSG setup and then check the box that says initial values and there I select the SST run .res file. I tried double precision too, but it would't work.
Seperatly, the SSG and the SST setup ran without any problem, I used the same mesh and boundary conditions, and only changed the turbulence model.
Thanks everyone in advance.
darazsbence is offline   Reply With Quote
Old   April 1, 2013, 18:40
Looks like a problem setting initial conditions. The SSG model will not be getting the Reynolds stresses from the SST model initial conditions, so have a look at how these are defined.
error code 1, ssg, sst, turbulence
[PyFoam] Why no non-zero return codes? Horus OpenFOAM Community Contributions 3 May 8, 2012 10:25
return in udf wlt_1985 FLUENT 5 September 21, 2011 04:35
Error in CFX Solver Leuchte CFX 5 November 6, 2010 06:12
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
