Creating polyline from surface intersection
Old   April 17, 2013, 09:00
Default Creating polyline from surface intersection
Rolando Figueiredo
RPFigueiredo is on a distinguished road
Hello!
Now that I am trying to post-process some results I can't figure out how to create polylines that are not on boundaries (unless you use a csv file).
Does anyone have a clue on how to create polylines by intersecting an interface boundary and a surface of revolution? ANoher question would be how to control the chart count? Apparently the default is 50 points, but sometimes I get 70...
Here's a pic to illustrate. Basically I want to mid-section the annulus!
Thanks!
RPFigueiredo is offline   Reply With Quote
Old   April 17, 2013, 21:36
mjgraf is on a distinguished road
you will most likely get more information and flexibility using the Turbo tab in CFD-Post.
Originally Posted by RPFigueiredo View Post
Hello!
Attachment 20862
Thanks!
mjgraf is offline   Reply With Quote
Old   April 18, 2013, 05:54
Rolando Figueiredo
Yeah, that helps a lot!
Cheers!
Old   April 18, 2013, 06:08
Rolando Figueiredo
Is there a better way to limit the circumferential turbo lines?
There's only the option to input the angles, but given the geometry that's kind of hard to determine!
Comsol (4.3): convert parametric surface into block? sgalaz COMSOL 0 November 9, 2012 09:20
killed "snappyHexMesh" parkh32 OpenFOAM Pre-Processing 2 April 8, 2012 17:12
How can I define a intersection surface with ICEM? BEN EZZEDDINE Anouar CFX 0 November 15, 2005 06:05
creating volume from a surface file for CFD Amir Main CFD Forum 0 December 24, 2002 02:08
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
