How tensor parameters to be entered in CFX-pre?
Old   May 4, 2013, 10:23
Exclamation How tensor parameters to be entered in CFX-pre?
hadi
hadi.iraji is on a distinguished road
hi
I m trying to simulate Flow through porous media and I'd enter the permeability parameter from a tensor.But I do not know how?
(ansys CFX-pre/defalt domaine/porous domaine/porosity setting/permeability)
(for Simulation of Vacuum Assisted Resin Transfer Molding process)
hadi.iraji is offline   Reply With Quote
Old   May 4, 2013, 10:25
Default help
hadi
Old   May 7, 2013, 04:04
hadi
ANSYS CFX presently allows only K(permeability) to be isotropic ( Ansys CFX help)
Old   May 10, 2013, 14:01
Erik
evcelica is on a distinguished road
You could try three different momentum sources (pourous loss model) one in each direction. Someone else had this idea, I've never tried it.
evcelica is offline   Reply With Quote
Old   May 10, 2013, 23:41
That's right. If you don't like the built in porous models you can always do your own.
But if he wants to specify it as a tensor it is a bit more complex - getting those high order terms in there will be tricky. But if all he wants is to specify a permeability in each direction this is easy to do with your own source term.
Old   May 11, 2013, 11:27
hadi
yes.I wants is to specify a permeability in each direction .
but how?
ansys CFX only accepts scaler for permeability.
"easy to do with your own source term". How?
Old   May 12, 2013, 07:08
The CFX porosity model just generates a source term. There is a little tricky stuff for convergence, but mainly a source term. But you can write your own source terms, so then you could write your own source term which is a porosity model which works in any way you like. So this means do not use the built in porosity model, use a source term instead and you will have to write the equations of the source term yourself - of course.
Old   May 13, 2013, 03:38
hadi
hi.
Thank you for answering my problem.
Where's sours equations can be entered. If possible, take an example.
THX
Old   May 13, 2013, 06:28
Look up source terms in the documentation.
Error while opening cfx file in cfx pre pks126 CFX 9 June 11, 2018 11:00
air ideal gas in CFX Pre wangy1767 CFX 9 October 1, 2012 07:55
CFX Pre Domains for centrifugal pump MechKim CFX 1 September 24, 2012 08:06
CFX Pre Hide symmetry symbols alvid CFX 2 August 15, 2007 11:34
CFX 10 -pre and -post problams on Linux Henry Liu CFX 3 June 22, 2006 06:57
