Question about using total energy equation or thermal equation |
May 6, 2013, 13:15 |
Meimei Wang
Rep Power: 15 |
HI,
The tutorial tell that, for low-speed flow, thermal equation could be used instead of total energy equation to accelerate the computation. But how to know whether my case is 'low-speed' or not? By the way, I'm simulating water. How to know whether the viscous term has to be included or not?
Best regards, Meimei |
May 6, 2013, 14:19 |
Mr CFD
Rep Power: 14 |
Only use the total energy equation related to high speed flow if compressibility is important. I think (I invite anyone to correct me here) it's a speed around mach 0.3 and above.
If you're using water, and your flow is subsonic you won't have heat generation due to viscous work, so I wouldn't worry about it. |
May 6, 2013, 16:40 |
#3 | |
Meimei Wang
Rep Power: 15 |
My flow speed is not that high. Is there is a way (or criteria) to detect whether viscous term need to be included or not?
May 6, 2013, 18:58 |
Rep Power: 143 |
The easiest way is to run a model with and without it and you will then see if it makes a difference.
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
What is the total energy for incompressible fluid? | Harry Dong | Main CFD Forum | 12 | February 4, 2006 00:55 |
Energy equation and Enthalpy | Martin | FLUENT | 1 | January 25, 2001 17:11 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
