CEL function tan, atan, asin, acos
Old   May 16, 2013, 16:28
Default CEL function tan, atan, asin, acos
Mickael
Leackim is on a distinguished road
I am a bit suprised, someone know how to use tan or atan function in CFD POST.
"ERROR
CCL parser failed with message:
Perl Syntax errors detected:
Undefined subroutine &CUEPost::asin called at (eval 1528) line 387."
Why coudln't we use those functions ?
Thanks
Mickael
Leackim is offline   Reply With Quote
Old   May 16, 2013, 18:48
This is a perl error, not a CEL error. So check your perl syntax.
Old   May 17, 2013, 08:08
Mickael
Thanks for your answer but i didn't know where i could make a mistake in my perl,
! $TEST=atan($RATIO);
In fact, if i remove atan by sin or cos it works so it's kind of strange.
I succed in my task though by using an expression defined as atan...
Regards
Mickael
Old   May 17, 2013, 09:18
The perl documentation (http://perldoc.perl.org/Math/Trig.html) states you have to have "use Math::Trig;" in your program to load the maths libraries to have the atan function available. The default perl gizmo only supports sin and cos.
Old   May 17, 2013, 10:30
Mickael
Thanks a lot
I didn't know it
Regards
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 10:20
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 06:27
inlet CEL function k and epsilon Nico CFX 1 April 26, 2005 16:20
How does STEP function work in CEL setup in CFX5.5 joseph CFX 1 April 5, 2002 23:06
